Question about Canon PIXMA MP530 All-In-One InkJet Printer
I want to throw away a Canon MP530 printer. I've heard memory stores all copies/faxes and I want to destroy memory before throwing away. How to I do this?
Posted by tlpeyes on
Dr. John Myers
    Master:
  • 411 Answers
If you're throwing it away, take a hammer to it. Once it's been fairly well destroyed, you should be able to find the memory card, and trash it. If not, trash all the internal boards. This has the added benefit of letting you work off a little everyday annoyance.
That's the simplest way, and the way the DOE/DOD does it, as well as many corporations....except they use an industrial shredder.
Posted on Jun 26, 2011
Testimonial: "Thanks for your help about the Canon MP530 memory card!"
hansr_imhof
    New Friend:
My drucke has uo52
Posted on Mar 20, 2013
Everytime I copy from the adf top feeder, I get a black line running down the copy. I've cleaned, reset, etc., and I sitll get the black line every time. Help!!!???
CClean The MX882 ADF (Automatic Document Feeder)
Be sure to turn off the power and unplug the power cord before cleaning the machine.
  • The power cannot be turned off while the machine is sending or receiving a fax, or when the received fax or unsent fax are stored in the machine's memory. Make sure if the machine completed sending or receiving all the faxes before disconnecting the power cord.
  • The machine cannot send or receive faxes when the power is turned off.
  • If you unplug the power cord, all the faxes stored in the machine's memory will be deleted.
    Print the necessary faxes or save them to the memory card/USB flash drive before unplugging the power cord.
  1. Open the Document Tray.
  2. Open the Document Feeder Cover.
  3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Document Feeder Cover (A).
  4. After wiping, close the Document Feeder Cover by pushing it until it clicks into place.
  5. Close the Document Tray. speed printer service
    http://www.smoothprinterservice.com/
Dec 18, 2012 | Canon MX882 All-In-One InkJet Printer
What to clear all info details out of my Canon MP530 printer before throwing out. How do I do that?
try two methodos.
To reset to default configurations settings:
Turn on
Press menu key. (use arroy to select "restore default"
press Ok.
To clear fax info
Press Menu key
arrow to select "Fax settings"
delete documents
Other settings like Phone number must be clean manually
I hope resolve your isuue
give a rate
Sep 15, 2011 | Canon PIXMA MP530 All-In-One InkJet...
How do I retrieve faxes from memory with my Canon MP530?
either use the fax function on the windows...and set the printer to see it ..or try to import from device with a photo manager or a pdf..(or word )
Jun 20, 2010 | Canon PIXMA MP530 All-In-One InkJet...
"waiting for report" won't go away and now machine refuses to fax
unplug your printer restart your computer and reconnect printer.
Mar 04, 2009 | Canon PIXMA MP530 All-In-One InkJet...
The fax messages just store in received memory but they don't print- how do I get it to print?
Yes - mine also did this when I was running out of ink - as soon as I replaced the cartridge, it printed everything in the memory straight away.
Feb 19, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Cannot fax ... Memory in use 0%
hii..
how long you have been using this fax.
Nov 07, 2008 | Canon PIXMA® MP530 All-In-One Printer
Won't print faxes
What printer are you using?
Mar 05, 2008 | Office Equipment & Supplies
Canon MIXPA MP530 Memory is full
I found this in a forum and I suspect it will work, remember that you'll need to clear the internal memory chip by unplugging the printer:
I got the dreaded "memory full" problem with my mp530 this morning. Couldn't FAX because the mp530 thought its memory was full even though it showed no documents in memory. The Canon site lists this symptom with a solution of 'turn off the unit, wait 10 seconds, then turn it back on'. Well that didn't work, so after multiple tries I noticed a post on this board (not really related) that suggested turning off the unit, unplugging it and waiting 10 minutes -- and that did the trick.
Dec 12, 2007 | Office Equipment & Supplies
Canon mp 530 fax
All in one fax MP530
Fax will not work.Memory full.How to empty memory?
Thanks
Nov 26, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Fax in memory
Print from Fax Memory on MP530
1- Press Fax,then Menu.
2- Press the Right Arrow Key to show 'Memory Reference' on the mini screen.Then press OK.
3 - Again use the arrow keys to show 'Print Document' on mini screen and press OK to print.
4- Once this has printed repeat the first 2 steps and on the 3rd step go to 'Delete Document' to allow you to print the next saved fax.
5- Repeat this till you have no more Fax's saved,then the light should go out in the top left corner.
Hope this helps.
Oct 09, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
466 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Tareq Bin Mostaq...
Tareq Bin Mostaq...
