SOURCE: Grundig Satellit 800 LCD display doesn't work correctly
If the radio uses memory batteries, try changing these with new alkalines. The microprocessor needs this power to drive the display.
SOURCE: We have a Grundig S350DL radio that was my
Hold down the power button for a second or two when turning it on to disable the timer. For AM reception issue, you could insert both ends of a long wire into the red and black connectors on the back to act as an extra AM/shortwave antenna, or connect a wire to a pipe, oven, or other grounded object and plug it into the black connector in order to improve reception. Those connectors snap to hold the wire in place.
SOURCE: Looking for inexpensive shortwave antenna for
Simple wire can make a great antenna, and it's relatively inexpensive. I've had the best shortwave and AM reception thus far using a long loop (actually a rectangle) of copper wire as an antenna (but folks shouldn't try a loop with some radios designed for use with powered antennas without inserting an appropriate capacitor in series). If you do try wire, you would want to try to make the loop shape as large as possible, and connect the ends of the wire to your radio's antenna connectors.
SOURCE: My Grundig G5 Radio only receives FM... no AM or
any fluorescent lighting of any kind nearby,plasma television,ceiling fan etc. in combination will
keep mine from receiving at all,just noise.if that doesn't work go outside and try a different area
