SOURCE: yamaha htr 5240 receiver, need fm antenna adapter
this is your manual http://www2.yamaha.co.jp/manual/pdf/av/english/re/HTR-5230.pdf
this is the 300 ohm adapter you need from radio shack and just install some small gauge speaker wire to it. or just splice the one that came with your receiver.
http://www.radioshack.com/product/index.jsp?productId=2062054
SOURCE: how to get am/fm stations to play. I have a hook
you can buy one online or you can make one out of audio, lamp, or antenna wire. cut about 10 ft of wire and split the wire about 1/4 to 1/3 of the way. that is to pull the two ends at one end of the wire in opposite directions. the wire looks like a T. the bottom of the T hooks to the receiver, the other end spreads out along the wall. the 2 ends at the rec. hook to fm and gnd or am and gnd. i hope i have made this clear.
reply if you need more help.
please rate bama46 and have a great day, thanks
SOURCE: Onkyo 8511 FM reception has
yes their is but you would need a local man to do it this is not something you can do yourself ,also of course it depends on the fault as some faults may cost more to fix than the set is worth .try a length of wire just pushed into the aerial plug and if its still the same then ask a local man but if its all microchips inside then it cannot be repaired very easly .could just be a broken wire on the inside of the set from the aerial socket to the board ,something right simple and a two minute job to repair
SOURCE: I'm trying to connect my
Is this what you need?
http://cgi.ebay.com/4pc-Gold-Plated-Aerial-Female-Aerial-Female-Adapter-/180435080974?pt=LH_DefaultDomain_0&hash=item2a02c4d70e
although I would be surprised if the signal you have would be correct to supply your fm tuner, you may be better off with something like this (depends on how good your fm signal is locally)
http://cgi.ebay.com/FM-AERIAL-KIT-RADIO-RECEIVERS-BALUN-UNIVERSAL-/310283558296?pt=LH_DefaultDomain_3&hash=item483e575d98#ht_2068wt_876
Alternatively, and I know this sounds crude, poke a long piece of wire into the centre of the aerial socket on your tuner and pin it to the wall or a door frame, it often works if you have a decent signal to begin with.
