Hi After reading the question it seems that the issue is with the spark module however, please elaborate and post back for further assistance. Daniel
Thanks for your reply Gerald.....please check this diagram....part no 4 is the spark module that is bad and should be replaced...
If you click on those links it tells you the part no and the number to call
I think the stock number is ccg2423w. As I turn on a burner other burners "turn on" their ignitors as well for different periods of time. There is no pattern to the problem. Please explain in detail how I may fix this problem. Cost of a service call is beyond my means at this time.
Gerald
Stock number may be ccg2423w. As I turn on a burner the ignitors of other burners "turn on" for different amounts of time. They soon stop. There is no pattern to the problem. I want detail instructions to resolve the problem.
Gerald
It is hard to understand. Is the sparl control unit INSIDE the cooktop bow or is it found inside the AC cox. I also need to know about wireing it up. Need more info
I also need the correct stock number for the part and a telephone number where I can call.
Gerald
