Question about Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer
My Whirlpool Cabrio dryer Mod. WED 6600 VWO won't
Posted by Allen on
William Howe
    New Friend:
When I turn the dryer on say to 40min,it shows does not come on and it goes to a F1 on the daily
Posted on Dec 28, 2017
5 Related Answers
Jimster
James Greene
  • 240 Answers
SOURCE: gas dryer makes loud hum
Sounds like you may have a motor issue, they can get lint trapped inside, and it causes the motor to overheat, and eventually go out. You can remove the top, then the front, and see if thats the problem. Usually, once the motor starts making noise, its time to replace. Right now, the packings in the motor are cold, and once they heat up, they stop making noise, so it could last quite a while.
Posted on Nov 16, 2008
kachbibi1
Bill Dickerson
  • 979 Answers
SOURCE: humming noise, runs and stops thru out drying process.
You have a motor that has a thermal overload built into it. This is for the dryer's protection. My best guess is to replace the motor. But before you do all that, make sure the wiring is good from the receptacle to the controls in the back of the dryer. It could not have a good connection thus causing this noise.
Posted on Feb 04, 2009
dray8165
  • 15 Answers
SOURCE: dryer wont start when start button is pressed, but humming sound
I'd sure start by making sure the belt isn't broken. You can usually see the belt with a flashlight after accessing the panel (some are in front, others in the rear) - don't go probing around bare armed without unplugging the unit....
Posted on Jul 20, 2009
ben fixit
  • 42 Answers
SOURCE: I have a Whirlpool dryer...Mod nu# WED5800SQ0,
Sounds like your capacitor has stopped functioning. Most dryers have capacitors ranging from 8 to 10 ohms which store energy and give the drum the initial energy boost to start it turning. Unplug the machine and take off the side that contains the motor. in there you will find a small cylindrical object with two connections, thats your capacitor, replace it
Posted on May 25, 2010
canwoodjc
Canwoodjc
  • 3301 Answers
SOURCE: Our Whirlpool Cabrio Elecetric dryer will not
it could be that or it could be the start button, you can check the button by adding a jumper in the wires that go to it,, this should be done as a check and not left that way,, for safety
Posted on Jul 03, 2011
Lid lock won't release on Cabrio washer
hey there have you tryed un plugging it the pluggin it back in
Nov 18, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool Cabrio dryer won't start - the sensing light stays on
An EXTREMELY helpful technical guide is folded inside the console housing.
WARNING: It is for appliance techs, DO NOT do the voltage/resistance checks if you are not well-versed in troubleshooting appliances! BUT, it does include putting the dryer in diagnostics mode and checking the sensors.
Post back any error codes you may get.
Oct 22, 2012 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
Whirlpool cabrio dryer has power but won't start
You may have a burnt out terminal block or start switch.
May 12, 2012 | Whirlpool WGD6400S Gas Dryer
Motor wouldn't start replaced the motor and it still won't start?
Did you replace the thermal limiter fuse inside the cabinet near the motor? It is likely burned out. Contact the repairclinic.com for the part or Sears.
Jan 19, 2012 | Whirlpool Dryers
Our Whirlpool Cabrio Elecetric dryer will not start. Model is WED6200SW1. We had just finsihed drying a load and put a 2nd load in, but it won't start. All the light come on. Could it be a sensor...
Jul 03, 2011 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
My whirlpool gas LGB6300PW0 dryer won't start. I press the start button and hear a humming noise, but no motor turning over. Please tell me that my 5 yr old dryer doesn't already need a new motor!...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 18, 2011 | Whirlpool LGV4634JQ Gas Dryer
Whirlpool mod WED 5500SQ0 how to change 3 prong plug to 4 prong plug?
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Dec 01, 2010 | Whirlpool WED5600S Dryer
Whirlpool Cabrio dryer gas does not stay lit after a few minutes.
It sounds like your solenoid coil(s) might be no good. Easy fix and not very expensive.
Jan 11, 2018 | Whirlpool Cabrio 7.0 Cu. Ft. Super...
May 24, 2010 | Whirlpool Dryers
Whirlpool Cabrio 7.0 Cu. Ft. Super Capacity Plus Electric Dryer Logo
922 people viewed this question
Top Whirlpool Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
jdthefixer
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
