there could be a couple of reason why it wont accept the radio pin.
Its possible that the radio pin you have is the orginal and maybe at same stage there was a fault with orginal radio and it was replaced under warranty the code wasn't updated .
Other is the bcm has been changed the codes hasn't been updated .
If you have the PIN and PUK numbers both, and none or any of them isn't working then. THe Code has been changed by your service providers.
Just contact your network provider and ask them for the code. They will give your your code for free. Its your right to know.
Regards, Waqar
Hello, Unless you have setup a PIN for scanning when you installed the printer the default PIN is 0000. If you setup a pin and don't remember, go to the Lexmark Productivity Studio, click on setup and diagnose printer, then on left side select Advanced, another screen will pop up click on Networking and another screen will appaer at the bottom there is a link that reads Change your PC name and PIN for network scanning, click there and you should be able to see and/or change the PIN. Good Luck and don't forget to rate this answer.
that's is a driver issue.. you need to uninstall your current printer driver and then restart your computer .. and then install it again,,, because your scanner application has been corrupt..
SOLUTION:
Download
the latest version (v 7.7.2) of the HP software from the HP website at
www.hp.com. Uninstall the previous software and then reinstall the
downloaded software.
WORKAROUND:
Follow the steps below:
Load the slides or negatives in the TMA and place it on the scanner glass.
Open Image Zone and click on
Scan Picture
to scan everything.
After
the scan is completed, change the settings from glass to scan
slide/negative from TMA. The unit will scan again and show the four
slides or negatives in the preview.
Click on the first picture in the scan preview and make the following changes:
change the dust and scratch removal/sharpness to none
change the resolution to 72 dpi
Click on the second picture in the scan preview and make the same changes described above.
Click on the third picture and then the fourth picture and make the same changes.
Click
Accept
. The correctly scanned slide or negative images will be saved in the Gallery.
Go to the Lexmark Imaging icon (located on the taskbar) and look to the left and down the bottom. You will see Network Settings, click on the "view or change network settings." When you get in, uncheck the "I WISH TO REQUIRE A PIN TO SCAN TO MY COMPUTER" and then press OK. This will remove the pin setting from your scanner. Lexmark technical support just did that for me, now my printer does not ask for a pin number.
If you have install HP s/w photosmart essential, you can scan material into coputer by selecting the get image function then select from scanner. A window will pop up. In which you can change the scanner parameter setup or accept the pre-scan quality and do the scan right away. Another method is in printer and fax folder, you can find the icon for scanner is located here too. Just click on the icon for scanner then you can get the scan result too. Hope this can help you.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
Load the original.
From the HP Director , click Scan Document .
From the HP Scanning dialog box, select the desired options and Scan to destination.
A preview of the image will appear in the HP Scan window.
Make any edits from the HP Scan window and click Accept .
Click Scan .
The document will open in the selected Scan to destination.
Scanning a picture
Load the original.
From the HP Director , click Scan Picture .
The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image.
The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan
To stop scanning, press Cancel on the front panel.
Hope this helps. Good Luck.
