Question about MSI MEGA Stick (256 MB) MP3 Player
Hi ! .I recorded my voice in the MSI 527. How may I play that record ? What button must I set to visualize and ear the archive. Thank you very much Marisa
Posted by marisandri20 on
ieshua concepcion
  • 43 Answers
To play a microphone recording file, press the Menu button once, and then push the Menu button to the right once, and now you should read the message of VOICE appearing on the Display. Press the Menu button again, and then use the Menu button to select a desired microphone recording file by pushing the Menu button to the right or to the left. Once the desired microphone recording file is selected, press the "play/pause" button to start playing the file.
this is all from the manual hope this helps
Posted on Jun 26, 2011
Voice recorder won't play back sound
Can you put this problem to an expert
Dec 15, 2013 | Tascam Dr-05 Portable Recorder
Cannot hear callers voice during a call but caller hears mine
if you cant hear caller voice. do one thing go to gallery and go to voice recorder and record some voice then save that then go to media and play recorded sound if its working means your loud speaker is working but not ear peic means (ear speaker) not working. so then you need to change ear speaker.you can do your self just watch video on online.
Dec 29, 2009 | Nokia N72 Cellular Phone
Sony ICD-P320 Handheld Digital Voice Recorder switch on and off
This voice recorder have auto power off function so does not have particular power on-off button, press play/ record to turn on and leave it for some time to turn off automatically.
Nov 11, 2009 | Sony ICD-P320 Digital Voice Recorder
Timer
You can schedule for automatic recording, specifying the start time
and end time of recording. When the timer-controlled recording
completes, the setting is released.
In Menu mode selection... SET, On, OFFAfter selecting SET, press the PLAY button to set the time to start the recording.
Apr 09, 2009 | Olympus VN-2100PC Digital Voice Recorder
VN-4100 transfer to CD
you will need a compaticord from the earphone of recorder to microphone of the computer. use the sound recorder software to record while you hit play on the recorder
Feb 27, 2009 | Olympus VN-2100PC Digital Voice Recorder
Cannot operate svr-925 digital recorder, need manual
How to Record:
1. Make sure HOLD switch (on side of unit with pocket clip) is set to off position (slide to right is off - to left would be hold)
2. For best results set unit with mic(rophone) which is on top of unit toward sound source and press REC/STOP button (Top button on front of unit just below LCD display). Recording will begin and will be indicated on LCD display.
> Red Record LED will be on and the message number, recording time will be displayed on the LCD.
3. To stop recording, press REC/STOP button one time.
* If no other buttons are pressed within 1 minute at stop position, it will power off automatically.
4. Pause during recording by simply pressing MODE/PAUSE button- press button again to resume.
There is a Voice Operated System (VOS) Recording button on left side also. You can record with voice activation to conserve recording space but I have found that you lose a portion of the recorded sound as it activates and if there is no sound for a very few minutes the unit powers off and you will get nothing further recorded. I recomend just keeping VOS in off position.
5. To erase a recording: Select the message number you want to erase and while it is stopped (the message number will appear in LCD with the length of recording showing also)
Press and hold the ERASE button until the LCD begins blinking "ERASE" then, while it's blinking simply press the erase button again and the recording will be erased.
6. To play back a recorded message find your message by "toggling" the switch on the right side of the unit that says INDEX. That switch is the fast forward/reverse play etc. To Play simply push the switch in. This button/switch takes a little practice to use but the Play portion is straight forward. Use the front buttons to pause and stop during playback.
Hope this helps.
Jan 04, 2009 | Sims SVR-S825 Handheld Digital Voice...
How do I connect the ka333 compaticrordto my pc to transfer what I have recorded there
connect to the mic of the computer and ear of the recorder. open up sound recorder. then play on the recorder and record in the software
Sep 22, 2008 | Olympus VN-3100PC Digital Voice Recorder
RECORD
Hey EMURK72,
According to information provided by the manufacturer, you should be able to enable voice recording by following the steps below:
1) Press the menu button ("M") twice to enter the main menu.
2) Press the "+" or "-" button to highlight "Voice Recording," then press the next track button to advance.
3) Press the "+" or "-" button to highlight "Record," then press the next track button to enter voice recording mode.
4) If you press the "●" button when the display screen says "Ready," you should then be able to start voice recording.
5) You can press the "Play/Pause" button to pause and resume recording.
6) Pressing the "●" button a second time stops recording.
If you'd like more information or step-by-step instructions that include visual aides, you may wish to refer to your owner's manual.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 03, 2008 | RCA TH1101 MP3 Player
Olympus DS30 voice recorder play speed issue
Hi, the solution to the problem seems to be the following. When u press play, once, you get 1x play. If whilst playing you press play a second time the DS-30 goes into slow play mode, and if you press a second time it goes into fast mode. For those of us who accidentally went into either fast or slow mode, just press the play button again, during playback, until "play" appears on the LCD screen. Apparently it is as simple as that.
Mar 03, 2008 | Olympus DS-30 Digital Voice Recorder
Sandisk sansa c240 mp3 player voice recording problems
Try the latest firmware upgrade from the Sansa website
Aug 03, 2007 | SanDisk Sansa c240 MP3 Player
MSI MEGA Stick (256 MB) MP3 Player Logo
Top MSI Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a MSI Audio Player and Recorder Expert? Answer questions, earn points and help others
