your gonna have to take vin# (located drivers side upper dash see through windshield) to your local suzuki dealer with your proof of owner ship registration,title, they will hook you up with new key
unistal the old version of itunes then download the new version here and i understand your bad english becouse i have that problem to becouse i from brazil and if work plese rate like very helpful and vote me thanks.
key off and out,diconnect negitive side of battrey then postive.clean terimals,charge battrey,connect postive cable (with key off)connect negitive.and start.
your dead battrey is taking up a big load on system,so when you boost it the dead battrey is taking it all the starter is geeting vey little.thats the clicking.
if you dont have a charger dicconect both terminals the same way again,put the jumper cables on the dead battrey.let it charge battrey for 10 15 mins .the longer the better.remover jumpers.
with key off and out conected battrey terminals.connect jumper cables and start.
let me know if it start or not hopefully the key hasnt lost its coding.
When connect ipod to computer, go to my computer. Click on ipod:- -click on tools, go to folder options -go to view tab -check: show hidden files -a ghost like folder will apear: ipod control -click on it and go to device -there will be a volmelocked file -click and delete it
I had a simalar problem ... plug it into the computer and hold down the off/on button and the home key for about 10 seconds and then leave go of the off/on button and continue to hold the home key until it says recovery mode on your computer.... it will delete everything off it but its the only way!!!
you can turn on your laptop if you dant have an removal battrey n then plug the charge back in and it will work fine however not only that check if the battrey shows any sign of leakeage also once your computer is back on then turn it off again and put the battrey back in if u do not have a removal battrey then keep the laptop unpluged for 5 minutes and try to turn it back on at least 2 times if u have done it then u could try tihis plug the charge wait for ten minutes see if it give u any sign of charging then turn the laptop on .
please try this out and see if it works as im not an it guy but justed wanted to help u
thanks
this is my e mail id [email protected]
can u please let me know if that worked for u or not thanks .
