Computers & Internet Logo
Posted on Jun 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an un-formatted DVD-RW. I want to record music on it. First how do I format it so I can record music, and second, can I record music on a DVD-RW?
Anonymous
Level 2:
New Friend:
  • Expert 138 Answers
  • Posted on Jun 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
138
Questions
0
Helped
24521
Points
407
No you cannot record music to a DVD-RW. You must use CD-R media to record music as CD players cannot read DVDs. However you can burn the music to the DVD if you plan on using a DVD player to play the music. I beleive some recording hardware does allow you to use DVD's, but most use CD-R media or digital media such as a hard drive or flash media.
When I record programmes to DVD they always seem to be in 4:3 format even if they are broadcast in 16:9. I have all settings on TV/Satellite/DVD set to 16:9 but the recorded DVD is still 4:3 format. Is...
16:9 recording is availbe on this unit.
Following are the available media to use for recording:
  • DVD-R/RW/+R/+RW; DVD+R Dual layer
I would try a different type of media.
Found this tidbit - *Not all options available for all disc formats.
2helpful
2answers
How do i rewrite over a disc that is full
If you are using a DVD-RW or DVD+RW, you can format the disc by performing "Format". You can format DVD-RW for either video mode recording or VR mode recording. DVD+RW can be format in order to erase all content of the disc.
You may not be able to reformat a disc that is not previously formatted by your recorder an example would be a. DVD disc formatted by PC or another recorder.
Follow these steps to re-write:
Insert a recordable disc.
1 Press [SETUP].
2 Select "DVD Menu",
then press [ENTER].
3 Then select "Format", and
press [ENTER].
4 select "Start", then
press [ENTER].
5 Confirm by selecting "Yes", then press
[ENTER].
Formatting will start.
6 Formatting is completed.
When the disc is ready for you to rewrite to "100%" is indicated.
Formatting 100%
1helpful
I'm having problems formatting discs for Panasonic EZ47 DVD recorder. Keep getting "formatting unsuccessful" message.
Now here are the types of DVDs that you can record to DVD-RAM, DVD-R, DVD-RW, DVD+RW, DVD+R, DVD+R DL, DVD-R DL
Now the only types that you can format are DVD-RAM, DVD-RW, DVD+RW
So first make sure you are not trying to format the wrong type of DVD. If you are using the correct type then you might want to try a different brand. Sometimes certain brands of DVDs have problems with certain players. You can also try updating your player's firmware and see if that corrects the problem also.
2answers
What disks to buy? dvdr dvdrw dvd+ dvd-????
DVD stands for Digital Versatile/Video Disc, DVDR stands for DVD Recordable and DVDRW for DVD ReWriteable. If you're familiar with regular audio/music CDs or regular DVD-Video discs, then you will know what a recordable DVD looks like. A recordable DVD stores up to 2 hours of very good quality DVD-Video, including several audio tracks in formats like stereo, Dolby Digital or DTS and also advanced menu systems, subtitles and still pictures that can be played by many standalone DVD Players and most computer DVD-ROMs. If you choose to lower the video quality it is possible to store several hours video on a recordable DVD using low bitrates and low resolution with video quality more like VHS, SVHS, SVCD, CVD or VCD. It is also possible to have up to 4.37* GB ordinary data or mix DVD-Video and data on a recordable DVD that can be played by most computer DVD-ROMs.
There are three competing DVD Recording standards, DVD-R/DVD-RW and DVD+R/DVD+RW have pretty similiar features and are compatible with many standalone DVD Players and most DVD-ROMs while DVD-RAM has less DVD Player and DVD-ROM compatibility but better recording features.
DVD-R and DVD-RW
DVD-R was the first DVD recording format released that was compatible with standalone DVD Players.
DVD-R is a non-rewriteable format and it is compatible with about 93% of all DVD Players and most DVD-ROMs.
DVD-RW is a rewriteable format and it is compatible with about 80% of all DVD Players and most DVD-ROMs.
DVD-R and DVD-RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double sided 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by DVDForum.
DVD+R and DVD+RW
DVD+R is a non-rewritable format and it is compatible with about 89% of all DVD Players and most DVD-ROMs.
DVD+RW is a rewritable format and is compatible with about 79% of all DVD Players and most DVD-ROMs.
DVD+R and DVD+RW supports single side 4.37 computer GB* DVDs(called DVD-5) and double side 8.75 computer GB* DVDs(called DVD-10).
These formats are supported by the DVD+RW Alliance.
DVD+R DL
DVD+R DL or called DVD+R9 is a Dual Layer writeable DVD+R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18).
DVD-R DL
DVD-R DL or called DVD-R9 is a Dual Layer writeable DVD-R. The dual layered discs can hold 7.95 computer GB* (called DVD-9) and dual layered double sides 15.9* computer GB (called dvd-18).
I got this info from http://answers.yahoo.com/question/index?qid=20071016055835AApo5e6
If your dvdrom supports dvdrw I would suggest buying these disks as you can re-write over them if you need too.
Most recent dvdroms support all of the above.
I hope this helps
What video formats can you play with slv-d360p?
Hi al - your unit can play the following formats:
DVD VIDEO
DVD -R / - RW
DVD +R / +RW
CD -R / -RW
VIDEO CD
MUSIC CD
The player can play CD-ROMs/CD-Rs/CD-RWs recorded in the following formats:
- music CD format
- video CD format
- MP3 audio tracks and JPEG image files of format conforming
to ISO 9660 * Level 1/Level 2, or its' extended format, Joliet Kodak Picture CD format.
*(A logical format of files and folders on CD-ROMs defined by ISO)
The player can play DVD-ROMs/DVD*RWs/DVD+Rs/DVD-Rs recorded in the following formats :
- MP3 audio tracks and JPEG image files of format conforming to UDF(Universal Disk Format).
In other words, just about everything. If this answers your question PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
2answers
Dvd do not record
The unit is saying that its an "Un-format disc" problem. Is this the only error code you are getting? Also, what types of DVDs are being used? As in, DVD-R DVD-RW DVD+R DVD-RW and what speeds? 1x 2x 4x 8x 16x?
Formating problem
Are you using dvd-rw(+) or dvd-rw(-). Have you tried updating the firmware? http://www.emersonaudiovideo.com/pdf/om/EWR10D4.pdf Minus (-R/-RW) and Plus (+R/+RW) The formats endorsed by the DVD Forum (www.dvdforum.org) have a hyphen in their names and are verbalized as "DVD Minus R" or "DVD Dash R" (DVD-R) and "DVD Minus RW" or "DVD Dash RW" (DVD-RW). The competing formats from the DVD+RW Alliance (www.dvdrw.com) use a plus sign: "DVD Plus R" (DVD+R) and "DVD Plus RW" (DVD+RW). Starting in 2002, drives that supported both Minus and Plus formats were introduced. Make sure you are using the proper dvd disc. Let me know what happens. Good Luck, Tim
Grand Canyon Tech
Grand Canyon Tech
