Question about Precor EFX 546i Elliptical Version 4
I need to order a new belt for my precor EFX 5.33 and can't find a site that I can order from...
Sportsmith LLC
  • Precor Master
  • 918 Answers
Confirm your model and serial number before purchase.
Drive Belts for Fitness Equipment Treadmills Bikes Ellipticals...
Posted on May 15, 2014
5 Related Answers
Anonymous
  • 13 Answers
SOURCE: i pulled the plug on my precor efx and now it wont
yes, we can help. 281-469-8506 www.nashsfitness.com
Posted on Aug 10, 2009
Anonymous
SOURCE: looking for repair manuals and error codes for
Could you please advice about ERROR 29 fo C956i/C966i treadmill.
Posted on Mar 04, 2010
maxtreadmill
John Mazmanian
  • 832 Answers
SOURCE: belt replacement for precor efx 645 verison 1
You may have to purchase the belt from a Precor dealer in you area, if you don't have one then call Precor directly @ 1-800-347-4404 and they will help you. Most of these part have not hit the secondary market yet and Precor pretty much call the shots.
Posted on Mar 13, 2010
Anonymous
  • 83 Answers
SOURCE: I own a Precor EFX 5.33 the drive belt snapped so
You use the two bolts that hold the step up pulley in place. The step up pulley is the pulley assembly that is closes to the back of the unit. The step up pulley slides into two grooves in the frame, then there is a bolt on each side that run down the groove into the step up pulley. These bolts are the bolts that adjust the tension for the skinny belt. You may need to loosen the other belt first then tighten the skinny then retighten the belt you replaced.
Posted on Mar 19, 2010
ZJLimited
ZJ Limited
  • 17970 Answers
SOURCE: How do I replace the
Check this reference guide in video: Precor+elliptical+trainer+change+belt
Hope helps.
Posted on Dec 28, 2010
My precor efx 546 makes noise like a squeaking in left pedal it seems I tried to tighten pedal but I the whole bolt and screw turn together and the other pedal makes no noise
This squeak is normally caused by a bad bearing in the wheel. In order to provide you with the correct wheel, I will need your serial number. The following link will take you to our Precor EFX 546 page.
Repair Parts for Precor EFX 546 Ellipticals SPORTSMITH net
May 29, 2014 | Exercise & Fitness
I want to replace the battery
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Precor Elliptical Models Affected:
  • EFX C524 with serial#s beginning I7, K7, LH, SW, SX
  • EFX C546 with serial#s beginning NF,SZ, IK, IL, IU
  • EFX C546I with serial#s beginning X8, XG, Z2
  • EFX C556 with serial#s beginning NG, SY
When replacing the battery on your Precor elliptical it is important to make sure that the battery terminals are not allowed to make contact with the metal surface of the battery bracket. **Damage to the battery will occur**.
Electrical tape can be wrapped around the battery terminals to prevent them from making contact with the metal surface of the battery bracket.
Battery replacement on the EFX C524, EFX C546, EFX C546i and EFX C556 instructs you to remove the (4) screws that fasten the battery bracket to the frame. This allows you to turn the lower PCA and battery assembly away from the frame so you can slide the battery out of the battery bracket. It may be necessary to remove the nut that fastens the front retaining bracket or "L" bracket in order to slide the battery out of the battery bracket.
Warning Notice for Battery Installation on Precor EFX Ellipticals
Feb 11, 2014 | Precor EFX 546i Elliptical Version 4
Precor EFX 546 Version 1 making clunking noise
Someone needs to look at this as noise issues can be from anywhere and anything.
877-805-1030
Book An appointment
Replacing battery
Feb 07, 2014 | Precor EFX 546i Elliptical Version 4
How do I replace the battery on efx 546i
Jan 01, 2014 | Precor EFX 546i Elliptical Version 4
How do i change the battery on a precor efx 5461
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH Warning Notice for Battery Installation of certain Precor Ellipticals This notice provides details about the battery replacement procedure that should be considered by anyone performing this repair. Following is the warning about the battery installation for certain models of the Precor ellipticals.
Dec 25, 2013 | Precor EFX 546i Elliptical Version 4
Replacing the battery
You can use the link below to access a service manual download. Please see page 68 for the battery replacement procedure.
http://www.sportsmith.net/images/product_support/precor/Service%20Manuals/Commercial%20EFX/C546i%20(version%203)(AJME,%20AMTE,ATRE).pdf
Aug 21, 2012 | Precor EFX 546i Elliptical Version 4
Precor efx 5.33 belt replacement
This link will take you to the replacement belt. If you use your serial number, you will be able to access a service manual on our Website to assist with the belt change. Drive Belt Poly EFX PPP000000010217131 SPORTSMITH net
Jul 01, 2012 | Precor EFX 546i Elliptical Version 4
My drive belt for my Precor EFX 5.33 broke. I have a replacement belt and would like detailed instructions on how to replace it.
Use this link and have your serial number ready. On the left of the screen, you will have the option to click on your serial number range. You should see a tab in the middle of the screen that shows manuals. Click on the service manual and you will have the information you're looking for.
Repair Parts for Precor 5 33 Ellipticals Consumer SPORTSMITH net
Feb 27, 2011 | Precor EFX 546i Elliptical Version 4
Belt replacement for precor efx 645 verison 1
Feb 26, 2010 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
105 people viewed this question
Top Precor Exercise & Fitness Experts
NOEL
NOEL
Ngoro
Andrew Taylor
Andrew Taylor
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
