Hello & Welcome to FixYa
Ld means long drain and is displayed when it takes longer than 5 minutes to pump out the water to a point where the pressure switch resets. To solve this problem make sure that the drain filter pump assembly located inside the bottom front panel is clean and after cleaning if the error returns then the pressure switch needs to be tested and if bad then it needs replacement. Please get back to me if you have any other questions.
Kevin
F32 Kevin
error code in your washer means pressure switch failure and is
displayed when there is no electrical supply to the pressure switch from the
CCU (central control unit) or if the pressure switch is bad and needs
replacement. You can check the pressure switch for continuity, if bad replacing
it is recommended repair. Please check these two repair manuals for your washer if you want to repair this yourself: first & second repair manual. Please get back to me if you have any other
questions.
You are welcome
Ave a maytag bravos quiet series 300 and had an error ld i think. turns on and has all the functions, selecting a type of wash begins to fill with water and rinse with soap does but after that cycle no longer makes of Washing rinse (clean water) stops and the display shows the letters LG.
there is no bottom front panel the front of the washer has no panels so any other thoughts on how to get to the pump assembly or is it the panel in the back?
also when we did the automatic fault codes we get a f32 code. dont know what that is either and are the 2 codes connected
thank you for your help
