Question about Razor MX350 DIRT ROCKET - BLUE
How long do you have to charge it for? , and do i leave it on or off?
Razorbase
    New Friend:
  • 11 Answers
The Razor MX350 will accept a charge if powered on or off, charging time is 8 hours, if the green light shows before this time still leave it plugged in as it may not be reading right.
Posted on Jul 05, 2011
  • Razorbase Jul 06, 2012
    It does not matter if its off or on as explained by Razor themselves, hardly helpful calling people an idiot! Regarding your light still being red after 8 hours have you tested the voltage on the battery as it may need replacing, 20v or lower it needs to be replaced.
Jenny Theiss
    New Friend:
  • 53 Answers
The charging process is detailed in the manual. You can download the user manuals, installation and trouble shooting guides from here
http://www.razorama.com/razor-owners-manuals.html
http://www.razorama.com/razor-installation-guides.html
Posted on Oct 25, 2013
Mark
    New Friend:
Off and my charger is brand new but we charge it for 8 and it's red oh well and you leave it off idiot
Posted on Jul 06, 2012
Harveywil609
Yah but how do you charge. What I mean is do you leave the moto bike on wiell chargeing or leave it off!!
Posted on May 27, 2012
Do I leave the switch on or off to charge my Motomaster battery pack?
Hi, You need to leave the switch on to charge any battery so leave it on. Please leave me feed back: Malcolm Campbell, Thanks.
Oct 31, 2017 | The Computers & Internet
CAN YOU LEAVE A RECHARGEABLE BATTERY FOR A 19.2 VOLT CRAFTSMAN CORDLESS DRILL IN THE CHARGER ALL THE TIME/
It depends on the charger taht comes with this drill, the dumb charger will just keep on charging the batteries even when it if fully charge and does not sop, which will be bad for the batteries, the smart charger (more expensive and has electronics inside the charger) will go into floating charge when the batteries are fully charge which will prevent the batteries from being overcharged. If in doubt, remove it from the charger after overnight charging.
Nov 23, 2011 | Drills
How long do you need to keep the camera charged? Leaving it on the docking station always being charged would damage the camera????
Leaving the camera on the charger will not hurt the battery. The type of battery you have will only charge till full and then stop charging.
Feb 28, 2011 | Kodak EasyShare DX4330 Digital Camera
The VEC0108BD has charged overnight, however, the recharge light still comes on when it is hooked to the car battery. Am I suppose to leave it attached to the battery?
If the battery is charged, you should unhook the charger. If you leave the charger hooked up to long it could possibly ruin your battery. If it is not charged you can leave it hooked up.
Jan 19, 2011 | Black & Decker Electrical Supplies
Battery wont charge
I would say leave it stay on then after its fully dead charge it up again . That should fix your problem if it doesn't leave a comment and ill try to help again.
Jan 09, 2010 | GPX Audio Players & Recorders
Zen 16 gig won't turn nor charge
hold down the reset button for about 1 min then leave it for about 30 seconds. once you have done that try turning it on, if it does not turn on and it is completely dead leave it pluged in to your computer by using the usb cable, leave for about 30 mins it then might start to charge, if it does start to charge leave it till it is fully charged and then it should turn on. if none of that works then i don't know.
Jan 06, 2009 | Creative Labs Zen Digital Media Player
When charging battery in car
You can leave it off while charging.
Jan 01, 2009 | Garmin nuvi 200W GPS Receiver
No problem, just ?
No issue. The charger is adapted to the battery. You can leave the battery over night in the charger without problem. The fact that the light goes off means that the charger surveys the voltage and switches off when the battery is charged.
If you leave it longer and the battery looses charge, it will be recharged automatically.
Cheers
Critter1965
Dec 27, 2008 | Olympus FE-340 Digital Camera
Digital camera nv20
charging the NV20 is simple, just plugin the cable to the power supply and it will charge. Inorder to charge the camera you must leave the battery inside the camera and when it's done charging you will see the lit up arrow on the end of the cable turn from red to green.
Dec 26, 2007 | Samsung NV20 Digital Camera
Durabrand Portable DVD Model # PDV-705
hi sir. any rechargable battery is to be treated like that way 1 -never leave the empty battery without charging any way because if you get it uncharged for one day you loose life time 2- charge it emmideatly after use for two hours or to end charging sign 3- evry two months try to completly discharge it and re charge 4- don't leave the batt, not working for more that 4 months 5- if you want to leave for more that 3 months charge it well and comletly please don't forget to do excelent rate cause i here to help you regards
May 06, 2007 | Durabrand DUR-1700 Portable DVD Player
Razor MX350 DIRT ROCKET - BLUE Logo
1,612 people viewed this question
Top Razor Cycling Experts
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Razor Cycling Expert? Answer questions, earn points and help others
