SOURCE: Buying New Straps Our Covers
Just go to the maxi cosi website and call the contact number. Or you can dowload the online usermanual, it has a order form.
SOURCE: Lost shoulder strap - need replacement part
sometimes if you call the company ,the first time you call them they will send you a new one free of charge ....you could try that...I know that is what cosco does.....
SOURCE: Maxi Cosi Prior XP Car Seat
If you contact www.maxi-cosi.com you will be able to order these parts or be put in touch with a more local company.
I hope this helps.
SOURCE: cant remove the cover off the straps at the bottom
Had the same problem where you are left with the cover trapped by the quick adjust part for the shoulder straps located near the foot of the seat. The solution, the strap does detach at the front of the seat. The loop that is stiched round what feels like a solid plastic part of the base, turns out that there is a gap in the plastic so push the strap to either side and pull it out through the gap. With this removed you should now be able to remove the cover completly and bung it in the washing machine on a hand wash.
SOURCE: is there any diagrams of
the secret is on the hidden gap at the front of the car seat ... where it appears to be in a fixed loop at the front slide it to the side to expose a hidden gap in the plastic .. you can then just slide the straps out...as easy as that !! ( easy when you know how)
