Question about Galaxy Radios DX-2547 40-Channels Base CB Radio
I WANT TO BUY A GALAXY 2547 CB RADIO. I FOUND ONE AND IT SAYS EXPORT USE ONLY . WHAT DOES IT MEAN, CAN I USE IT. THANKS
Posted by jharw on
Sam U. El
    New Friend:
  • 4 Answers
If it is a modified 2547, I doubt the person who modified it would put "for export only" on it.
Since you didn't say anything about more than 40 channels (frequencies), it could be an early serial # from the time before the 2547 was approved by the FCC for sale in the US and only sold as legit to overseas markets. The Galaxy DX 2547 has been made in one version or another for quite a while. The early models have lesser TX finals and a couple bugs that was ironed out in later versions of the 2547.
Posted on Sep 21, 2012
wcrave
    New Friend:
    Problem Solver:
  • 19 Answers
Normally, this radio will only work on CB frequencies. I suspect the radio has been modified to get channels below and above the regular 40. If so, the radio is no longer type-accepted by FCC. It is unlikely you would get into trouble using the radio.
....Don at NTCB, Inc.
Posted on Jun 27, 2011
How do I add channels to the Galaxy DX 2547
you have to buy a switch at radio shack that will let you add channels I think its a # 275-1386A .Then the fun begins . Heres where to go to get the rest of the information so if I print one thing wrong you can't yell that I told you to do it. These are the correct directions @ www.cbtricks.com look for galaxy 2547 and then look for freq conv and it all yours.
Jun 15, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy dx 2547 base cb frequency drift problems
for upper ssb adjust L21 for 16.51250 mhz . adjust L22 for 16.50750 for lower ssb. you do have a frequency counter don't you ?
Jan 01, 2012 | Galaxy Radios DX-2547 40-Channels Base CB...
How to install echo board in a Galaxy 2547
  • The DX2547 is the same as a Galaxy 959 - a SSB/AM CB radio. The standard of echo boards is the TRB-X2. This installs the same way in most CB radios. I have uploaded an instruction sheet here http://minus.com/lbkZJ6ZfR6qbEY Very easy to follow. If you happen to have any further questions please feel free to ask.
  • Hope this helps..
Nov 03, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
Need bulb replacement for DX 2547 meter for swr,mod,power and etc. Thanks
You will more than likely need to get the OEM part for this as I do not know of an after market. There is only one place in the country that sells them. Maycomm Communications www.maycomcomm.com They are the only one in the US that deals in new OEM Galaxy radio parts. That is where I go for parts for Galaxy radios I cannot find. You can also call some random CB shops to see if the have that meter from a parts radio they have laying around but for me, if I open a radio, I use new parts only. Good luck. Maycomm will fix you up.
Feb 16, 2011 | Galaxy Radios DX-2547 40-Channels Base CB...
90900237 is the serial number on my galaxy 2547
According to a post in a recent forum it was made in September of 2009. I am not sure this info is accurate but it was published as such.
Jun 12, 2010 | Galaxy Radios DX-2547 40-Channels Base CB...
My galaxy 2517 (NO TX)
if you have another radio put it right next to the 2547. turn on the monitor radio with no antenna on the same channel and key the 2547. if you can hear it the final transistor is bad. let me know if that worked
Jul 18, 2009 | Galaxy Radios DX-2517 CB Radio
Galaxy 2547
Is there a dial marked RX Gain? Does this radio have this feature?
M3ODQ
Feb 01, 2009 | Galaxy Radios DX-2547 40-Channels Base CB...
Galaxy Radios DX-2547 40-Channels Base CB Radio Logo
144 people viewed this question
Top Galaxy Radios Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Are you a Galaxy Radios Radio Communication Expert? Answer questions, earn points and help others
