RCA 20F512T 20" TV Logo
Anonymous Posted on Jun 25, 2011
How to unlock FTA? - RCA 20F512T 20" TV
Electro Med Services
Level 3:
  • RCA Master 6,694 Answers
  • Posted on Jun 25, 2011
RCA Master
Level 3:
Answers
6694
Questions
Helped
1871024
Points
21433
Hello
you must have its original remote control to unlock the set. If you haven't its original remote handset with you, try to borrow it from any of your friends or relatives who owns the same model. After unloking it, you can use universal remote.
Most RCA sets use a four digit code to control the v-chip. The code reset is different depending on the model. Try each number until you find the one that works for you.
  1. Hold down the MENU button on the remote and VOLUME DOWN button on the TV it's self at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  2. Hold down the 0 (zero) button on the remote and the VOLUME DOWN button on the TV itself at the same time for at least 4 seconds. The set won't say so, but the lock will be unlocked
  3. Hold down the MENU button on the front of the TV and the TV button on the remote at the same time for at least 4 seconds. 4- Hold down GO BACK button on the remote and MENU button on the front of the TV at the same time for at least 4 seconds.
Hold down EJECT button on the front of the TV set and the MENU button on the remote at the same time for at least 4 seconds. Depending on the model, one of the methods should unlock the V-chip. Now, if desired, you can change the settings on the V-chip by going to the MENU and going to PARENTAL CONTROLS, or on some sets, going to MENU and then going to TV SETUP, then to V-CHIP SET
OK.
I'm serving timefor a felony fta in California . Could I petition for resentencing and reduction on a felony fta if the charge I failed to appear for was dismissed?
Your sentence is for "failure to appear", not for the original charge. The two violations are separate charges. Dismissing one does not dismiss the other.
Activation of keys on an FTAS receivers
Your query > "Instructions on how to install new keys and activate an FTA receiver using a 2GB Cruzer Micro Flash Drive with 3 smarth technology"
Generic responses:
1. depending on your FTA receiver (brand/model/version) (BlackBird, MultiStar, UltraStar, Pansat, Digiwave, Viewsat, Coolsat, Fortec, Ariza, Twinhan... or even clones) you would need to download the appropriate firmware/satellite keys using your PC & Internet connection;
2. links to firmware/satellite keys maybe available from your FTA receiver manufacturer's website or forums such as HashHU FTA
3. in your PC, unzip the downloaded firmware/satellite keys to a temporary folder;
If you are using a stand-alone hardware FTA box:
a. plug in your 2GB Cruzer Micro Flash Drive to one of your PC's USB port;
b. copy/paste the unzipped files in the root directory of the Flash Drive. Verify that you have the .bin or .pmg of whatever your FTA box is using;
c. remove flash drive from PC's USB port and insert into the USB port of the FTA receiver;
d. on the FTA box, using your remote, go to Menu, Settings or Sytem Information, keys, firmware or receiver Upgrade, select USB, select Flash, Save, Activate or Upgrade;
e. wait until the FTA box has uploaded to itself the new firmware/satellite keys;
f. reboot (power on/off).
If you are using PC-based FTA satellite receiver:
i. run your FTA receiver program;
ii. select for Tools/Options/Upgrade or Update;
iii. browse/direct to search in your temporary folder where downloaded files were unzipped;
iv. once found, click OK/Update/Upgrade;
v. in some brand/model/version, there is an auto upgrade/update feature which will download appropriate firmware/satellite keys if you are online.
Hope that the this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
How to hook up fta dish net.
i dont recomend a non profesional to connect a new install for fta theres lots of tech things to consider when going to fta , site,typedata,size,obstructions etc.
ck your local listings for a qualified sat dealer that does installs
25helpful
2answers
How to unlock coship cdvb5110d receiver?
i have CDVB11OD coshib receiver when i try to install fta channel that time message is dislpya "insert card" how to solve this problem
1helpful
What is an fta lock
FTA means "Free to Air"
It mostly means your unit can't do decoding of encrypted channels, and is locked to FTA.
It may also be if your unit was sold by a specific provider that is is locked to their own channels.
6helpful
2answers
I need the remote code for receiver echolink
echolink EL-700 FTA receiver unlocking code please solved it ?
Pansat 2500a FTA receiver
I would suggest to go here to get a lot more info on how to program this receiver.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
