Question about Western Digital 320GB MyBook External USB 2.0 Hard Drive
Hi Sir My samsung 400 GB external HDD bought from Malaysia is not detecting in My PC. the LED is glowing.. Sathya Bangalore
Posted by sathyajithvi on
Ben Ef
    Scholar:
  • 85 Answers
I am very sorry but malaysian products are not supported with a samsung 400gb hard drive. If you go to a store though they may be able to unlock it like unlocking a iphone
Posted on Jun 25, 2011
External Hard disk is not detecting on my desktop PC
Try a different usb port. Maybe a 1TB external hd is too big for your old computer to recognize. Old computers cannot handle a drive that large.
1helpful
HA 100-00bootcode- HANARO2 ENGINE
RESPECTED SIR, MY 80 GB SAMSUNG HDD NOT DETECTING AND ITS SHOWING ERROR "BOOTCODE-HANARO 2 ENGINE (REV1) HA100-00
1helpful
Hi.. i need help.. my external hdd transcend store jet 320gb have problem... when I conect HDD to pc blue led blink just one time and hdd stop working..
Check that the USB cable can provide enough power to the hdd. Check that the USB port is powered. Older USB slots may not have enough power to run larger external HDDs, there you may require separate power to be plugged into the hdd. Are you using the original USB cable provided with the external HDD?
2helpful
2answers
External HDD is not detecting
Below is the address of Seagate Service center in Bangalore.
ACCEL Frontline Ltd, No: 18/8,
Saleh Centre, Cunnigham Road,
Bangalore - 560052
Karnataka.
Ph: 080 66279903
You can reach them online @ http://myservice.accelfrontline.in/WRMS/
Regards
Manish
3answers
Bios not detecting 320gb sata drive
Double check the jumper configuration, You might also want to check the cables and ports incase that's the problem because a properly jumpered SATA drive shouldn't have any compatibility issues. Also check if *********** board supports the SATA ? Let me know if this works..thanks. Mike
I formatted the drive and erased all content now i dont have the start up software for it to run when i plug it in
My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
What is the problem? & what to do to get back my necessary files stored in the 500 GB HDD.
Can any one help me, please? URGENT.My External HDD of Western Digital (500 GB) not detecting by Win-XP SP-2. But at the same machine another External HDD of Western Digital (160 GB) is detecting and functioning well.
1helpful
3answers
WD 250 GB external hard drive is not being detected by system
Hi !
First check if your WD is running (spinning), no matter if the blue light is on. Can you hear it close with your ear, or feel vibrations on your hand when it starts.
If it runs, then check/replace the USB cable you are using with another.
Check the Power supply if it gives necessary power.
If you are familliar with disassembling/assembling, then open and remove the HDD from the box and try to connect the disc directly to your PC (using another HDD Data/Power cables).
If it runs, and you can acces it, then something is wrong with the Box.
If it doesn't, then the HDD is broken or damaged.
Please note that if your device is under warranty, DO NOT open the box ! Contact your seller for service/replacement instructions.
Regards.
HDD PROBLEM
Raj...
A few questions..
Is it external/internal drive
what kind of data connector does it have... USB, Wide ribbon cable or 6 pin sata
Has this drivbe got windows or linux on it, or is it just used for data.
Western Digital 320GB MyBook External USB 2.0 Hard Drive Logo
Top Western Digital Computers & Internet Experts
Ekse
Mike
Michael Thomas
Michael Thomas
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
