Computers & Internet Logo
Posted on Jun 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How can i Transfer music files to my microSD card?
Anonymous
Level 2:
President:
  • Expert 739 Answers
  • Posted on Jun 25, 2011
Anonymous
Expert
Level 2:
President:
Answers
739
Questions
Helped
182662
Points
259
Connect yr sd card to computer using card reader, then just copy and paste to yr memory card
TQ
Anonymous
Level 1:
Problem Solver:
  • Contributor 9 Answers
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
9
Questions
0
Helped
986
Points
25
Most computers, if not all as I haven't encountered any do not have a direct slot for microSD cards. There are available converters in the market that convert it to a regular sized SD card, another option is to get a USB card reader.
With Windows, just right click on the file you're copying and open up My Computer (or press the Windows button and E at the same time) and you should see a new item under "Devices with removable storage", it should be your microSD card. Just copy/cut the files to that device.
Hope this helps!
1helpful
How do I put music and pictures on my sd card
Erin, Check the attached links,instruction and guides to move music,etc. to SD card, Good luck. "I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to transfer files apps media to microSD on an Android phone or tablet
How to move pictures videos music to SD card
How can transfer my music from my S5 to the SD card
Easy Guide on How to Move Music to SD Card
Jul 19, 2016 • Cell Phones
1helpful
How can I download music to my fusion2 phone
First you:
2.9.1 Using the microSD Card as USB Mass Storage
To transfer all your favorite music and pictures from your PC to your mobile phone's microSD card, set the microSD card as USB mass storage.
1. Connect your mobile phone to your PC with the USB cable provided. Your PC will detect the microSD card as a removable storage device.
2. Open the notification bar, and then touch USB connected.
3. Touch Turn on USB storage in the dialog box that opens to confirm that you want to transfer files You can now transfer files from your PC to your mobile phone's microSD card. When your microSD card acts as USB mass storage, your mobile phone will not use this memory space. Ensure that you follow the correct procedures to disconnect the USB mass storage device (your mobile phone) from the PC when you have finished transferring files.
Then:
8.3.1 Copying Music to the microSD Card
1. Connect the phone to your computer with a USB cable and mount the microSD card.
2. On the PC, navigate to the USB drive and open it.
3. Create a folder in the root directory of the microSD card (for example, Music).
4. Copy the music from your computer to the folder you have created.
5. After copying music, unmount or eject the drive as required by your PC's operating system to safely remove the mobile phone.
6. Disconnect the mobile phone from the PC.
Once done open music player and play music.
Ref: http://www.att.com/support_static_files/manuals/ATT_Fusion2.pdf
Computer isnt recognizing micro sd but cell phone does. I'd like to transfer mp3 files from computer onto cell with microsd
leave the sd micro in cell and connect the cell via usb to pc/laptop..go to my computer on pc you should see a new drive yes the cell card copy/paste or click/drag your mp3 files to cell from your music folder
How do you download music from our computer to the
It is hard to provide any useful suggestions without knowing the type of cell phone your son is using.
Normally he would put the memory card in the cell phone microSD slot (provided it can support 2gb card), plug the USB cable from computer to cell phone (if it supports this). Normally the phone will have also got some software apps CD which should be loaded to computer. This will provide the necessary functions to load music files to the phone.
Alternative to USB is bluetooth connection which both the computer and the cell phone will have to support. He can transfer music files that way.
I am not sure if he can copy the files directly from the computer to the memory card and play it on the cell phone as data formats are not standard. Also iTunes files need to converted to mp3 format. If these are protected iTunes files then it becomes a bit harder - best to burn a CD and then rip into mp3 format.
Once again these suggestions are useless if cell phone cannot play music (mp3 or WMA etc) files, does not have microSD slot, does not have USB or bluetooth support.
1helpful
2answers
Transferring music files to microSD card
It says on the manual this this phone accepts microSD™
memory cards up to 2 GB (depending on memory
card manufacturer and type). Check with your phone manufacturer if there are known issues with a particular memory card brand.
Also, try connecting the memory card to your computer via memory card reader and see if the card will be detected. That way, you can check whether the card is working or not. Save the music files from the PC to the memory card, then see if the music files will appear when you insert the card to your phone.
I cant transfer any music to my card
right click on the device that is your cards ad reformat your card that should sort your problem
regards AL
2answers
How to put music on a lg scoop
hi,
Start by formatting the MicroSD card
1. Insert a microSD card into the phone.
2. Press OK to enter the Main Menu.
3. Within Settings/Tools select Memory then press OK.
4. Press 3 to select Card Memory.
5. Press the Right Soft Key under Format.
6. Press the OK key for Yes.
To Transfer Music
7. Connect the USB cable between the phone and your PC.
8. Press OK to select Transfer Music.
9. Press OK again to confirm disabling voice calls.
10. On the computer, drag and drop music files into the drive.
MicroSD does not contain supported music files
I went back to the US Cellular store and presented the problem to the salesman that sold me the phone. He said that I needed to remove the memory card and put it in a card reader and transfer the music files to the card through the card reader. My Gateway desktop has a card reader and I transferred the music files to the card and then to My Music folder under My computer and it worked. Strange to have to do it this way but it works.
2answers
My music
1) get a MicroSD card (it'll come with an adapter)
2) on your computer, transfer the mp3 files to the microSD
3) put the microSD in your phone.
Music Transfer
If that phone came from Verizon, it will only play v-cast songs.  That's how they get you to buy it.  By saying it's a "music player"
Grand Canyon Tech
Grand Canyon Tech
