Run antivirus software, run a registry cleaner and defrag the hard drive. Is the machine running hot? This can cause problems like: slow processing, PC freezing up and PC shutting down. Make sure all the vents are clear of dust and the fan is working properly.
Hi Possible reason why the computer running slow and sometimes freezing its because of the hard drive or the storage is almost full try to defrag the local drive and try to unistall software that you dont need anymore.
You probably have a number of viruses on your computer. My suggestion is to download these two programs and uninstall your current anti-virus software (if any).
You will want to run this free program as soon as you download it. It will remove any viruses on your computer. This is a great tool to use about once a month to make sure your computer is clean. Do a full scan and wait for it to complete. If you have completed the steps above and still have the problem, you will need more RAM. RAM is temporary memory that your computer uses when it is on. If you have very low RAM, then you will have a very slow computer.
Registry Fragmentation
Registry is accessed by almostall the installed programs and your operating system itself. Why is computerslow and freezing has to do with the fragmented registry data. You have todownload a PC Optimizer software that includes Registry Defragmenter tool suchas Reginout to perform system maintenance tasks.
b>
Too Many Programs areInstalled
Installing too many programs makeyour computer slow and freezing. You have to uninstall the unwanted programs.
1. Click Start ' Control Panel. 2. Click Programs ' Uninstall a Program. 3. Select a program to remove. 4. Click Uninstall button. 5. Follow the wizard. 6. Reboot the computer after completion.
b>
Insufficient RAM
Sometimes computer runs slow andstarts freezing due to an insufficient RAM. You have to install additional RAMsif required.
b>
Lack of Proper Configurations
You will feel that your computeris slow and freezing if you haven't set Windows for best performance.
1. Right click My Computer. 2. Select Properties. 3. Click Advanced System Settings. 4. Click Advanced tab. 5. Click Settings button under Performance frame. 6. Select the option Adjust for best performance. 7. Click Apply ' OK ' OK.
b>
Junk Registry Keys
Storing junk entries in theregistry makes your computer slow and freezing. You have to delete such junkentries using a Registry Cleaner and PC Optimizer software.
Run your antivirus program. There may be something slowing your computer that you can remove. It is a good idea to run your antivirus program every week. Step 2
Remove spyware. Run a good spyware tool at least twice a month. Step 3
Use a pop-up blocker, if you have one. Check your antivirus program.
Dispose of the Extras
Step 1
Delete your document files for anything you no longer need. Saved pictures, audio and video files in particular can slow your computer.
Step 2
Remove unwanted programs from the Control Panel area. Old toolbars or games the kids downloaded off the Internet are a good place to start. Look for software you no longer use, such as the old printer you threw out last year.
Step 3
Clean out your email. Old messages are a constant drain on your computer's resources. Go through every folder, deleting everything you do not need. Leave no mail! Finish by emptying the Deleted Items folder.
Step 4
Turn off unnecessary programs. Check your taskbar for icons that show running programs. Disable anything you are not currently using.
Run Maintenance
Step 1
Run the Disk Cleanup tool located in your Control Panel. (Windows only. For other operating systems, please check the Resources section below.) This will remove temporary files, cookies and unnecessary components to speed up your computer.
Step 2
Defragment your computer. Defragging takes some time, but will speed your computer significantly. You can find the tool in your Control Panel. Run it monthly.
Step 3
Check for disk errors. Sometimes corrupted files slow down your computer. To find and fix these files, Go to My Computer and right-click on C drive. Choose Properties, then Tools.
You may want to look into upgrading your RAM if there is less than 2GB installed. This is a recommendation that I have found in working with several PC's running this Operating System. Also, you would want to run disk clean up and remove any temporary files that Windows finds. Deleting any other temporary or unused files from your PC on a regular basis should increase system performance. In addition, if these steps do not solve your problem, you may want to consider upgrading to a faster performance hard drive (preferably a SATA II with a 32MB cache). As a last resort, you may look at your CPU to see if there is an upgrade for it, as well. Keep in mind that Vista is a resource hog and can slow down a PC within just a short period of time.
the problem is u have a lot stored on the pc memory and when this are much it slow down your computer so what u need to do is check your desktop and delet some things u no longer needs or dont open too much pages on your home page this can make your pc slow down ok,thnks .
you can speed up your pc by deleting old files and clearing caches etc.. see the link for step by step instruction it may help you http://soluzia.net/speedupurpc.php
