Question about Onkyo TX-SR603X Receiver
I tried using zone 2 on my AV Reicerver today and i got a message that "read pwrd z2 not act" It is an Onkyo TX-SR603X.
Posted by billyhowell8 on
David Dunn
    Brigadier General:
  • 8,546 Answers
You have to set the Powered Zone 2. It's in the manual.
See page 75.
Posted on Jun 25, 2011
I Have The ONKYO TX-SR603X receiver ALL BY ITSELF I NEED HELP RESETTING IT
Hello, please see the procedure below to reset the receiver
Resetting the AV receiver to its factory defaults To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VIDEO 1] button, press the [STANDBY/ON] button. "CLEAR" will appear on the display and the AV receiver will enter Standby mode
Apr 26, 2017 | Onkyo Audio Players & Recorders
"pwrd z2 not act"
Look in your speaker setup menu. he selection for zone 2 is usually in there
Mar 31, 2013 | Audio Players & Recorders
How can I run a turntable through the onkyo tx-sr603x?
Look on the back of the system, if there is phono input, that is what you can use to connect the turntable without using an external pre amp
Aug 27, 2011 | Onkyo TX-SR603X Receiver
Message states the power to zone 2 is not activated when trying to listen to zone 2 speakers. Nothing in my manual about this message. How do I activate power to zone 2 on a tx-sr601
Page 77:
"Not available in Zone 2 mode" Setting not allowed because the Zone 2 mode is turned on.
"Zone 2 is not On" Will not work because the Zone 2 has not been turned on.
TURN ZONE 2 ON.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR601-Receivers-manual/id/365ag212/t/2/
Page 55 shows the prerequisite settings for using the surround back terminals for Zone 2.
Page 60 describes USING Zone 2 and points out that only analog sources can be used with Zone 2. Are you trying to use digital sources? Read the notes regarding REC OUT.
Jul 07, 2011 | Onkyo TX-SR601 Receiver
Zone 2 stopped working. When pressing the volume button for Zone 2 , message appears : "Pwrd Z2 not Act." Do you know how to correct?
Go into Hardware Setup, find the setting for Powered Zone 2 and ACTIVATE IT. You will lose the Surround Back speaker function when you do this. Zone 2 and Surr Back are mutually exclusive.
Jul 14, 2010 | Onkyo TX-SR703 Receiver
I have an onkyo receiver tx-sr603x. I can get
audio amplifier´s damaged need to be replaced
May 25, 2010 | Onkyo TX-SR605 Receiver
Power outage overnight. Now, Onkyo TX-SR603X no
Depending upon the type of power outage, you may have more of a confused receiver than a defecive one. Try unplugging the unit for an hour or so to see if that resets the whole thing back to "normal". If not, then further investigation with a scope or logic analyser will be required to determine whether the problem is with the internal CPU or a defect on the data lines. Unless the reset works, this is not likely to be a DYI repair.
Dan
Mar 28, 2010 | Onkyo TX-SR603X Receiver
ONKYO AV RECEIVER TX-SR603X
When I initially bough mine, I had the same problem. It wouldn't shut down, but occasional popping sound on the center speaker. Turns out the impedance on the speaker was 4 ohms, not not 8. Replaced center with an o 8ohm speaker. This receiver is not reated to run 4 ohm speakers. If I had problems with 1, I can only imagine what kind of problems could happen if all the speakers were 4-ohms.
Oct 14, 2007 | Onkyo TX-SR603X Receiver
Onkyo TX-SR603X Receiver Logo
484 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
