Brother IntelliFAX 775 Plain Paper Thermal transfer Fax Logo
Question about Brother IntelliFAX 775 Plain Paper Thermal transfer Fax
I need to reprint the last inoming fax. HELP!!!
Posted by kclivermore on
Anonymous
    New Friend:
  • 41 Answers
Printing a Fax in Memory If you have Fax Storage ON for remote retrieval, you can still print a fax in the memory when you are at your machine: 1 Press Menu/Set, 8, 4. 2 Press Fax Start. 3 Press Stop/Exit. (See Turning On Fax Storage, page R-2.) Polling For details about the Polling feature, call our Brother fax-back system 1-800-521-2846 (in USA), 1-800-681-9838 (in Canada) and request at the Index. (See Features That Are Not in the Manual, page 6-6 for details.) Polling is the process of retrieving faxes from another fax machine. You can use your fax machine to "poll" other machines, or you can have someone poll your machine. All parties involved in polling need to set up their fax machines to accommodate polling. When someone polls your machine to receive a fax, they pay for the call; if you poll someone's fax machine to receive a fax, you pay for the call. (See Canceling a Scheduled Job, page 6-5.) Some fax machines do not respond to the Polling feature.
Posted on Jun 24, 2011
I want to reprint the last incoming fax because it was unreadable. I also just replaced the toner drum. Still get "replace toner drum" message.
You can't do a reprint of the last fax it's not possible on any fax machine I'm aware of you'll need to contact whoever sent you the fax to resend
REPRINT FAX
I suspect you look in the history and pick the last job printed if you are in a confidential environment then all the information would be deleted after printing and you would need to re-send the original document again.
Good Luck.
1helpful
The unit continues to reprint the last fax. When trying to fax it reboots itself and reprints the last fax again
Have you tried going to Hewlett Packs web page I believe there is a firmware update for that printer. That hopefully should take care of it. If you are still having problems call Hp directly and tell them what is going on. You pay good money for there printers that is the least they could do for you is help you out when things don't work correctly. FYI ( if you have to resort to calling hp on the phone be patient because they are not the fastest tech support around and at times it can be very frustrating waiting) Good Luck!
Reprint last fax?
you cant reprint.if your fax paper jamed or your machine had an error you can reprint.when you get a fax automaticallay your memory will be clean
2helpful
NEED TO REPRINT RECEIVED FAX HP OFFICEJET 4500
Yes, You can.
Press Settings (The Wrench Button)
Navigate to "Print Report" - Press OK
Navigate to "Reprint Faxes" - Press OK
"Reprint All Faxes" - Press OK
Or Navigate to "Reprint One" - Press OK
Navigate to Date/Time Received of fax to reprint - Press OK
3helpful
Reprint a fax
Sorry, once a fax is printed, it is gone from memory.
2helpful
Reprint Last FAX on RICOH Aficio MP 3350
Once the fax was received and printed you can't do nothing.
It is not stored in the machine.
Please call the sender to send you the fax again.
Good luck and please rate me, thanks.
1helpful
Reprint last incoming fax
i'm afraid you are out of luck. Once an attempt is made printing and no error message about the ink cartridge condition is apparent. Then that's it, it is deemed successful.
Norman  J Weimar Jr
Norman J Weimar Jr
Gary
Gary
