Question about Ryobi Multi-Volt Battery Charger
Battery not charging. Orange and Green light on charger. 18V Plus one system
Posted by havaiisteve on
  • havaiisteve Jun 24, 2011
    the lights are not blinking.
wallygatorca
    New Friend:
The air holes on the bottom of the batteries are there for the battery to vent. Downside is, these vents can also allow moisture to get in and prevent contacts from letting the battery charge and causing the "defective" display on the charger.
I work on pool and spa equipment and I had dropped my batteries in a small puddle of water where I was working, both went dead immediately and both showed "defective" on the charger even after drying them out for a few days.
Tried using a can of air and gave each of the vent holes several shots... The batteries charged and are now working perfectly.
I'm sure even overnight condensation could be the culprit for a charger to display "Defective"
Posted on Jan 11, 2012
  • Ryobi Master
  • 6,183 Answers
Are the lights blinking or steady?
On my Ryobi battery charger (dual-chemistry), if the red and green lights are both blinking, the battery is damaged and will not accept a charge. Replace the battery and dispose of the old one properly. (Places like Home Depot and battery shops will take the old battery for recycling.)
The older NiCd battery charger that we had indicated a bad battery when the yellow and green lights came on.
These batteries do have a finite number of times that they can be recharged. When they start to fail, one cell usually will go bad. It's generally not worth trying to replace one cell.
Manuals for the Ryobi One+ tools are http://www.ryobitools.com/catalog/18v_oneplus#/overview . Click on the tool or battery pack to get the Owner's Manual. (Manuals are not on the charger page.)
On rare occassions the charger can fail. If a new battery doesn't charge, then replace the charger.
I hope this helps.
Posted on Jun 24, 2011
  • Cindy Wells Jun 24, 2011
    Based on the "steady lights", I think you have the older charger. If the yellow and green lights are steady, you may have a bad battery or a completely discharged one. If the red light doesn't come on after 30 minutes with the battery on the charger, then you have a bad battery. (To me the lights look yellow, green and red (from left to right). I've assumed the the light I consider yellow is the one you call orange. The red light is marked Rapid Charge and the green is Charged.) As I said before, if a new battery isn't charging, then the charger itself is bad. (Since you see the lights, it isn't the power supply of the charger.)
    Only the new charger has blinking lights for the status information.
    I hope this helps.
    (we have both the old one for NiCd batteries only and the dual chemistry charger.)
EthanGavin
    New Friend:
    Problem Solver:
  • 10 Answers
Most battery charger have Orange or yellow for the status indication, you may try keep charging for long if its the first time and see...
Posted on Apr 03, 2013
I have a brand new Ryobi kit put battery in the charger the red light goes on and the green light flashers on and off is this charging or should the green light go off until battery is charged.
When the battery is charged the green will be steady on and the red will go off. Flashing green is an indication that it is charging.
hope this helps?
Jan 19, 2016 | Ryobi 18v Combo Kit P845 4-tools/...
Ryobi 18v battery charger is not charging
If yellow and green light come on and stay on then your battery is bad if not get a new charger
Jul 22, 2014 | Ryobi 140237039 18V Ni-Cd Battery Charger
I have a black & decker pivot plus that will not charge. How do I know if I need a battery or if I need a charger?
Batteries are only good for about a year, if they are older than that, take them back to the store and see if they are guaranteed at all, (all Ryobi tools and batteries have a date code on them, and they are all guaranteed for 2 years, a little plug for Ryobi,) that is all I buy now days, they work great. So, to check your charger, you will need a volt meter set on 12 or 20 v dc, and see if the charger is putting out, if not, then, the cost of a new ryobi might be the same as the fix for the black and decker. That is if you use the thing, we use our cordless tools every day and charge them every night, hope this helps.
Jun 28, 2011 | Black & Decker Pivot Plus Cordless...
When i place a 18v battery which is dead on the charger both red and green lights come on and stay on. This is happening with both batteries. and neither holds a good charge. What is the problem? It is...
In some model the FUSE got burn.But if this is not your case one or both,batts and charger are burn.Try first to change the batt, then if this not work, change the charger.
Nov 08, 2010 | Ryobi Multi-Volt Battery Charger
Ryobi p103 battery charged but dosen't work.
You need to have the charger tested, if you know that batteries are good then what else could it be. This LIon charger has a logic circuit in it like a computer.
May 17, 2017 | Ryobi Two 18V Lithium-Ion Batteries +...
Light on ryobi 18v charger
More than likely a defective battery sinse the other ones charge fine..
Bring it back for exchange of another one..
Note;
We are helping people here every day on a points system.
If the information provided here was at all helpful,
please be kind and rate well.
Thank you – and enjoy your day ;o)
Jul 31, 2009 | Drills
Battery wont charge green light and orange light come on but no charging happens, i have 3 other of the same batteries and they charge and work fine.
Is this an old battery? Batteries can fail and not charge after a lot of use. If it's new, run it all the way dead, then try to recharge .
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jul 03, 2009 | Ryobi Two 18V Lithium-Ion Batteries +...
MAKITA LXT BATTERY CHARGER
hey
flashing orange=cooling abnormality.
you need to wait for the battery to cool.
see my mod page, it has all light explanations in it.
Have fun
Avi
Jan 09, 2009 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Ryobi Multi-Volt Battery Charger Logo
11,065 people viewed this question
Top Ryobi Drills Experts
JOHN LAPIER
Marvin
Marvin
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
