Question about Dell 1815dn All-In-One Laser Printer
My Dell MFP 1815dn has a paper Jam 2. I removed the toner cartridge and pulled the paper out, before I realized that I needed to open the back. I believe I thought I got the paper out, but the printer is still giving the Jam 2 error. What is the next step to take?
Posted by dtmccrary558 on
Gale Todd
  • 1,116 Answers
After a paper jam occurs in the rear cover of a Dell Laser Multi-Function Printer 1815N, the printer will not resume when the jammed paper is removed. This is the normal behavior of the printer as there is no sensor on the rear cover of this printer.
To open the back cover and remove any stuck paper, perform the following steps:
  1. Open and close the front cover.
    The jammed paper may automatically exit the printer. If the paper does not exit, go to the next step.
  2. Gently pull the paper out of the output tray.
  3. If you cannot see the paper in the output tray or the paper does not move when pulled, open the rear cover.
  4. Skip to step 9. If you do not see the paper, go to the next step.If you see the jammed paper, push the two blue pressure levers up and remove the paper.
  5. Release the blue strap, the rear cover stopper, and fully open the rear cover.
  6. Unfold the duplex guide fully.
  7. While pushing the fuser lever to the right, open the fuser door. NOTICE: Make sure to unfold the duplex guide before opening the fuser door, or the fuser door may be damaged.
  8. Pull the jammed paper out.
  9. Return the levers, fuser door, rear cover stopper, and duplex guide to their original position.
  10. Close the rear cover.
  11. Open and close the front cover.
    Printing automatically resumes.
Posted on Jun 24, 2011
  • 1 more comment
  • sherrell Feb 08, 2013
    tried this a printer does not resume printing, instead it keeps beeping and will not print, scan, nothing; even after you triple check everything and turn power on/off
  • sarah dutler Aug 27, 2013
    I am experiencing the same error message with my dell 2145cn model.
    I am experiencing the same problem. It just doesn't reset.
Dell MFP 1815dn continuously feeds paper when printing
There might be a paper jam or issue with the drum .. please remove the jammed paper or contact authorised dell support
Oct 05, 2016 | Dell Laser MFP 1815
Can't get it to work after a paper jam.
Inorder to remove the paper jam inside, you need to remove the toner cartridge first and then you can pull out the paper jammmed. If there is still paper jammed inside. Open the printer power to roll over and paper comes out. If still paper still there, You can open the back side of the printer to remove some paper jammed.
Nov 13, 2010 | Dell 1320c Laser Printer
Paper jam ,no paper jam found Dell 1815dn
give this a try
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 01, 2009 | Dell 1815dn All-In-One Laser Printer
Fuser paper jam on Dell mono laser mfp 1125
Please double check if all doors --- including the paper tray cover --- are firmly (repeat FIRMLY !) closed --- seemingly all such are designed as precautionary measures for safety operations.
Jan 28, 2009 | Office Equipment & Supplies
Dell 3010cn paper jam 075-134
Step1
Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
Step
Step
Step
Step
5
If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
Step
6
If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
Step
7
If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
Step
8
Step
9
Nov 12, 2008 | Dell 3010cn Laser Printer
Laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
Oct 08, 2008 | HP LaserJet M4345 MultiFunction Printer
Fading on one side of the paper - Dell 1815dn laser MFP
The Printhead IS located above the toner cartridge on this model. There is a small opening that allows the laser light to shine through the case to the imaging unit on the toner, but you can not access the the laser without disassembling the printer.
Even though this is a new toner cartridge, it may be defective, even more likely if it is a non-Dell or remanufactured toner. Try reinstalling the old toner cartridge. Even if it prints light because it is low, if it is uniform across the page then the new toner is defective. Return or exchange it with the manufacture.
Sep 25, 2008 | Office Equipment & Supplies
Paper Jam feeder
Step1
Step
Step
Step
Step
5
Step
6
Step
7
Step
8
Step
9
Aug 14, 2008 | Dell 3100cn Laser Printer
Paper Jam?!
did you ever wonder why they were in the waste in the first place. ?
If you,ve got lots of them, you could experiment by swapping parts over, from the others which may have different faults.
hope this helps Mike @ Compurepair.
Feb 21, 2008 | Computers & Internet
Dell printer problem
Sounds like you may need to replace the pick up rollers on the machine.  Without knowing exactly where the jam error happens during the print process, it's hard to say.
Oct 19, 2007 | Office Equipment & Supplies
Dell 1815dn All-In-One Laser Printer Logo
2,169 people viewed this question
Top Dell Office Equipment & Supplies Experts
Richard C Cohen
Richard C Cohen
Marvin
Marvin
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
