SOURCE: MAGIC CHEF CTF1920ARA - Freezer works, Refrig. portion does not.
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If you don’t know what these are then unplug the machine and let the ice
melt in the freezer overnight with the door open. Then try it the next day, if
is cooling fine then you need to have a service person replace one of the above
items.
SOURCE: Where do you put the rinse agent in a magic chef dishwasher ?
there should be a place in the door.
SOURCE: Magic Chef Model #MCO160UW
Call 888-775-0202 Magic chef they will replace the part free of charge even if its not longer under warranty
SOURCE: water not entering dishwasher. Worked fine one
The water-inlet valve lets water enter the machine. First Check to see if the valve is getting water. Make sure it’s not clogged. There is a screen on the inside of the valve, this sometimes gets clogged up with debris. Check to see if you get power to valve when unit is put into operation may take a couple minutes to start a fill. If you have power and it’s not clogged up replace the valve .If you have no power to the water inlet valve check float switch. This can be done by checking the continuity. There is a video of this at http://appliancehelponline.com/dishfloatwaterinletvideo.html this will walk you checking the water inlet valve and the float switch. It may be a different model but the testing procedure will be the same. You can also enter your model # for diagrams and illustrations for most models. All parts come with installation instructions.
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
