SOURCE: How do i install an arc shower curtain rod
you cant you need studs.get the spring loaded rod.
SOURCE: adjustable (tension) shower curtain rod too long
Yes you can ! You only have to pull off the rubber end cap and cut it , file off ant burrs. Cut the SMALLER diameter end only, the other end contains the spring !
SOURCE: hand held shower head leaking
If it leaks continuously during use, verify that a rubber washer was used in that connection and that the connection is tight.
If it only leaks after the water is shut-off, there is a vacuum breaker installed there, which prevents water from siphoning back into your water system. It is normal for water to drain at this connection when the water is shut off.
