Dear agapemini501,
the symptoms show that your operating system is crashed please restore your system .for restoring please insert your recovery CD that got with your laptop and please restart and press F12 and boot from CD.in the cd you will get option to restore .
thanks for your posting
There are a couple of quick fixes you can do.
First, boot into Safe Mode (Repeatedly tap the F8 key while the system is booting, before the windows logo appears) A Menu will pop up, press Boot Into Safe Mode. From there you can try a System Restore to a known good date.
System Restore - Click Start -> Control Panel -> On the top right, type "System Restore" without the quotes. Click on "Restore system files and settings from a restore point". You can choose the recommended restore or a specific date.
The other option is to boot into "Last Known Good Configuration". To do this, use the F8 trick again while booting, but instead of Safe Mode choose "Last Known Good Configuration".
Please note that either of these run a risk of some data being lost from the time the restore point was made. You "shouldn't" lose anything but just want to make you aware.
Hello, doing a "last known good
configuration" Works most of the time. Here is how to do it:
1. Make sure your computer is powered down.
2. Turn your computer on and immediately
start pressing F8 on your keyboard repeatedly until you see a black screen with white writing that gives you a list of boot
options.
3. Use the down arrow on your keyboard to
select the Last Known Good Configuration (Advanced) option.
4. Press Enter on your keyboard
and cross your fingers.
Good Luck!
