Hi, try removing the spray arms and see if they are clogged - and of course unclog them. Also might be inlet valve. If you are at all technical, find it, remove it, see if it is clogged - if you have hard water - which most people do - it will clog up and should be replaced. You can use vinegar and special cleaning agents but most likely the problem is as aforementioned.
