Question about Lenovo 3000 N200 PC Notebook
My mouse pad cursor do move but it doest whant to enter if i tab on it
Posted by Dirk on
Andrew Calhoun
    Novelist:
  • 182 Answers
Some touch pads have a setting that must be set to allow a tap to be interpreted as a click. Go to Start-->control panel-->mouse, and look for a setting that tells the touch pad to allow it to sense clicks on the touch pad instead of requiring a button to be pressed. If not, try updating your touch pad driver. Start, right click on computer, click on Manage, when computer management window opens, click on the device manager in the left pane. Find mice and other pointing devices in the middle pane, and click the small triangle to the left of it, to expand it. Find the one under there that stands for your touch pad, and right-click on it, and click "Update Driver software." make sure you are connected to the internet first, and let it connect to Windows Update to see if it can find a newer driver.
Posted on Jan 27, 2012
3 Related Answers
Anonymous
  • 45 Answers
SOURCE: the mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Posted on Aug 21, 2009
Anonymous
  • 9 Answers
SOURCE: Mouse cursor moving by itself
Have you tried to alter the mouse properties? Go to Control Panel > Mouse, for XP. Some of the settings in here might help.
Posted on Dec 12, 2007
Anonymous
  • 72 Answers
try using a usb mouse first , if the problem still persists theres a problem with the hardware controller.
Posted on Feb 18, 2008
The cursor will not move I think I have locked the touch pad by mistake
Use a temporary external USB mouse, Click Start button from your laptop. Type "mouse" in Search Program & Files, click mouse under control panel. click Hardware tab,click properties, click change settings, click driver tab, check if the device is enable or click update diver or rollback driver if necessary.
Aug 25, 2014 | Fujitsu Siemens ESPRIMO MOBILE V5535...
Unstable, jittery cursor
Lets give this a try: Click the Start button> click Control Panel> click Hardware> and then click Mouse. Click the Pointer Options tab, and then do the following: Uncheck the Hide pointer while typing box. Hope this helps you. Let us know either way. Make it a great day!
Apr 30, 2012 | Compaq Computers & Internet
When I try to plug in an external Mouse my Acer Aspire One is asking me to download hidusb.sys from the XP Home Edtion Service Pack 3 CD?
I'll assume your touchpad and built-in mouse are not working, hence your need for the USB mouse. If the touch pad and built-in mouse are working but you find them awkward to use (another reason some users connect USB mice to notebooks), then you might find it easier to briefly persevere and use the touchpad and built-in mouse for only a few seconds just to complete the simple steps outlined below. If not, the keyboard method detailed below is less efficient and more cumbersome but equally effective.
This driver that is being requested is already built-in to Windows. Use the TAB and down or up arrows keys on your keyboard to move the cursor to the button you want to activate -> press the ENTER key to activate the button that the cursor has settled on keys on your Click Next -> No (to alternative search methods) -> search the whole computer for the driver -> next -> finish -> if your USB mouse does not work straight away, press the windows logo key bottom left of your keyboard -> the use the keyboard arrow keys to move once up and then left to the shutdown button -> press ENTER -> use the arrow keys to move the cursor to RESTART -> press ENTER.
Nov 15, 2011 | Acer Aspire One PC Notebook
I cannot move the arrow
Perhaps your mouse is not plugged in to the computer. If your mouse is a usb mouse it will have an end of it that looks like this:
http://cache.gawkerassets.com/assets/images/4/2008/11/usb3.jpg
It probably isn't blue on the inside though. It's probably silver or black
If your mouse is a ps2 mouse then it will look like this:
http://www.york.ac.uk/admin/sro/Photos/PS2connection2.JPG
If the mouse is a ps2 mouse then when you plug it back in you will need to log off and then log back on to your computer for it to work. To log off you can press the windows key that looks like this:
http://daily-grind.net/wp-content/uploads/2010/08/Windows-Key-722215.jpg
and then use the tab button to navigate to the log off button and hit enter. Then hit tab until you can select yes and hit enter.
If it is a usb mouse then you can just plug it back in and it will work.
May 09, 2011 | Computers & Internet
How do you set the time on the Logitech keyboard MX3200
Please do the following:
1. Make sure that the time and date are shown on the LCD. If necessary, press (FN + F9) until the time and date are shown on LCD.
2. Press (FN + F10). You are now in 'Set mode' - you can exit this at any time by pressing the Esc key.
3. Set the correct hour by either typing the numbers on the numeric pad or using the cursor up and down keys, followed by Tab or Enter.
4. Set the correct minutes by either typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
5. Choose either 12-hour clock or 24-hour clock by pressing the cursor up or down keys to switch between the options. Then press Tab or Enter.
6. Set the correct month either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
7. Set the correct day either by typing the numbers or using the cursor up and down keys, followed by Tab or Enter.
Jan 18, 2010 | Logitech Cordless Desktop MX3200 Laser...
How do I disable touch pad when using a mouse? ASUS K50IJ Win7 64 bit
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
Unfortunately, there are no keyboard shortcuts to enable/disable Touchpad movement or tapping. You can however drag the Mouse icon from the control panel to your Quick launch bar for quick access.
If that sounds too much effort, you may consider adjusting the sensitivity of the touchpad. This can be accessed from the Touch Pad tab of our mouse properties. Choose a low setting.
You can also go to link below to get help.
http://labnol.blogspot.com/2007/05/disable-touch-pad-of-your-laptop-avoid.html
Dec 30, 2009 | ASUS A6U Notebook
The mouse cursor moving itself
Tach pad is clean and set the tachpad speed in contorl panal
speed is select slow and save in laptop ......................after check 95 % your problem is solve
Mar 30, 2009 | Dell Latitude D600 Notebook
Cursor jumps around
If your cursor moves erratically on the screen (for example, if it jumps around the screen, moves at varying speeds, or selects items on its own), perform the following steps:
  1. Clean the surface of the touchpad with a dry, soft cloth to remove grease, sweat, moisture, or other liquids.
  2. Adjust the sensitivity of the touch pad:.
    1. Click the Start button and click Control Panel.
    2. Click Printers and Other Hardware.
    3. Click Mouse.
    4. When the Mouse Properties window appears, click the Pointer Options tab. (Figure 1)
      Figure 1: Pointer Speed
    5. Under Select a pointer speed:, click to move the slider bar closer to Slow.
    6. Click OK.
    7. Check to see if the touch pad still behaves erratically.
  3. If the touchpad still caused the cursor to behave erratically, attach an external mouse to your computer and restart your computer. Use the external mouse to see if your cursor still moves erratically.
Aug 14, 2008 | Computers & Internet
Mouse pad problem, cursor is moving but click function is not working
Try to enter BIOS (press ESC on start up) and see if mousepad is set correctly.
Otherwise try to download updated drivers from Toshiba website.
Aug 08, 2008 | Acer Aspire 5610-4648 Notebook
Lenovo 3000 N200 PC Notebook Logo
110 people viewed this question
Top Lenovo Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
