Had this machine for YEARS never used. I want instructions how to turn the FAX portion on. Last year tried to load software to use as printer ad Dell machine refused to allow?????
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines.This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10.The replacement kit part number is 80040.You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer. What are “Agitator Dogs”?These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle.They can (and do) wear out dependent upon the use of the washer.If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs. SYMPTOMS REQURING REPLACEMENT:The agitator fails to turn during the wash cycle, or will not turn with a heavy load.The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run.The washer will also drain normally.The only indication that something is wrong will be the agitator slipping or not turning at all.The result will be clothes that do not wash properly and will sit on the bottom of the wash tub. To replace the Agitator Dogs, follow these steps:
Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
Remove the center bolt of the agitator.You will have either a 7/16” hex bolt or a recessed square plastic nut.If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
Remove the agitator by grasping the bottom flange and carefully pulling straight up.Try to keep all the parts assembled while doing this, so do not pull too hard.This will make this repair much easier.
Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand.The agitator dog assembly will come out in your hand.
With the agitator dog assembly in your hand, lay the rest of the agitator aside.Pay careful attention to how the dogs are installed.Remove the worn dogs and reinstall new ones.It’s that simple.
With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
Carefully align and reinsert the upper portion of the agitator to the lower portion.Again, making sure the two pieces align correctly.
Place the entire agitator assembly back on the gearcase shaft and reinstall center nut.NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly.Just make the nut snug.Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair.Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.If you get confused and require further assistance, please refer to my profile at http://www.fixya.com/users/jsrock516 and use the “Ask Me” feature.For excellent diagrams to assist in reassembly you can also refer to the searspartsdirect.com website.Just type in your COMPLETE washer model number and look under the Agitator Parts heading.I hope this information is found to be helpful.
After using this printer for two years with high speed USB turned on, I began getting the same error message. It is not a memory issue.
The solution was to get into the machine menu and turn off high speed USB. I can only assume that HP broke something with a firmware update.
How to turn off High Speed USB.
Push the Menu button on the printer. Scroll over to the "Service" menu. Push "Enter". Scroll to High Speed USB, push "enter". Turn High Speed USB "OFF". It fixes it but makes everything sloooow.
HP no longer manufactures or supports this machine and I have been unable to get Windows 7 software other than the generic universal driver.
This will be my last HP. It has been a good machine but HP software sucks!
Each phone or dial-up modem or fax machine needs a DSL filter attached to the phone line/socket then each phone or dial-up or fax machine is then plugged into this filter.
The DSL modem does not require a filter.
If your fax is part of the computer's modem then a filter is also required on the line-in on the modem.
The instructions for sending & receiving depends upon your system/dial-up modem (the make & model, is it stand alone or a modem adapter on the expansion slot or built-in on the motherboard) and the software you are using. Cannot help you without these details.
Check if you received a software disc for the fax machine portion . If not go out to canon USA web site and look up software and downloads. You should find and download the fax software, which is required to make you machine work.
use the CD installer that came with the Lexmark 9500 and do a clean fresh install. Do not plug in the printer/fax until instructed to do so. Pls follow on screen instructions.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
the scanner works with the windows built in driver. Uninstall the hole mfc suite and reinstall after restart. This is the fix for the software.
You can check the hardware simply by copying a page. If you can copy there is no hardware prob.
Post here again if it does not work and let me know your windows version, too, please.
