Question about Motorola Televison & Video
I have a Toshiba 32 DT1u attached to a Comcast HD/DVR cable box. I've used all the codes for toshib and cant get the remote to turn the TV OFF using the 'all on' button. It works to turn the box and TV on, but when I want to turn it off, only the box turns off. To turn the TV off, I press TV then power.
Posted by decoss on
4 Related Answers
Anonymous
  • 129 Answers
SOURCE: universal remote code needed for motorola cable box (for comcast)
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC8800
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
Many thanks
Mark
(www.sparky-uk.com)
Posted on Dec 21, 2007
Anonymous
SOURCE: comcast remote's ok button doesn't work with xbox 360
Sorry, the Red Button won't work, but you can map the A button on the Comcast remote instead. It's almost the same thing... Your fingers will barely know the difference.
1. Press the Aux button at the top of the remote.
2. Hold the Setup button until the Aux button flashes twice.
3. Enter 994 on the keypad. The Aux button will flash twice again.
4. Now push the Setup button once. Enter 00001.
Finally, push the A button The Aux button will flash twice. You now have the A / Select / OK / Green button mapped on the Xbox360.
--If you want to switch the A button back to default, just do the same sequence but this time push the A button twice.--
Posted on Apr 16, 2009
Anonymous
SOURCE: Sharp TV (LC52D64U) remote control Comcast cable (DVR) box ?
I had the same problem with my remote. I would enter the code and there would be no response from the remote. I looked up the manual for the other comcast remote and the codes are 5 digits instead of 4. Try codes 10093 or 11602. The reason why there is no response from your remote is because it is waiting for you to enter the last digit of the code. Hope this helps.
Posted on Aug 11, 2009
Anonymous
  • 712 Answers
SOURCE: Code for Comcast DVR box
Locate the code of your device in manufacturer's codes on the back of the user guide. Brands are listed in the alphabetical order with the most popular codes listed first.
Posted on Feb 05, 2010
Why does my Samsung not turn off my cable box?
It sounds like the box and TV are out of sync. If the DVR is shut off, turn off the TV manually (NOT with the remote.) The next time you hit the power on the remote, both units should power up together. Make sure the remote is pointed at both device at the same time and slowly sweep the remote to hit both of them while holding the power button. I have always used the cable/DVR remote to control my devices and left the TV remote in a basket for setup stuff only on the TV.
I can't get my Comcast remote control to sync up with this sylvania 32in HD tv. I tried every code in the Comcast DVR manual under sylvania tv's and nothing, I would love a fix to this problem.
the tv is likely to be generic in nature i.e. parts used by many manufacturers. if you knew what tv builder actually designed it you could find the code. does the remote have a search feature if so use it, it should find something that operates most tv functions eventually
35helpful
2answers
Can't get my hannspree remote to work with comcast
10030 for the comcast dvr remote. Code is from NEC
3helpful
TV CODES FOR 32'' RCA HD TV
if you bought a new rca tv, the codes have changed. until the cable companies catch up, you will need to use the remote that came with our tv AND the remote that came with your comcast box. Or, you can buy a LEARNING UNIVERSAL remote. this is different than a regular universal remote.
1helpful
Closed captions will not work thru my tv remote
I hope this was resolved but this is a dish page and I am unable to answer Comcast issues.
2answers
Programming the Acquos Remote
There is a code out there to try.  The code would be 47.  Just follow the steps in your manual on how to program this box and you should be able to go from there. Can't garantee that it will work as that code came out with the newer tv but it should work.
25helpful
8answers
Program Comcast remote to operate Samsung 46"LCD
The answer depends whether its a Comcast DVR Remote or a regular one. The DVR codes are 4 digit -- the others are 5 digit. I got 0060 to work for my DVR remote.
45helpful
8answers
Turn off closed caption on input(component) on Sharp Aquos 42"
Had this happen on a Comcast box (Motorola DCT 6416 III)
Here's how to fix it:
Turn the cable box off, leave fully connected. Press Menu on the remote
The cable box internal menu will display (Not the Comcast one the Motorola one-- i.e. Display ratios-16:9 etc It's in black and white)
Use the arrows to cursor to the Closed Captioning and toggle to "Disabled" Press Manu again to exit and Voila!
Power the box on an have at it
2helpful
2answers
Jumbo Universal Remote
I have a Motorola DVR from Comcast. Code 051 will make all the cable functions work. Haven't figured out how to do anything with the DVR bits,
Televison & Video Logo
Top Motorola Televison & Video Experts
Joaquim Martins
ray gallant
Are you a Motorola Televison and Video Expert? Answer questions, earn points and help others
