so that is not really a questions -- do you need to know it's address on the network? Do you need to know the IP from your ISP that you are connected to? Or do you need to know the IP from a SIM card that you are using to connect.
You could also add the why if you don't know the other information -- someone should be able to tell you what address you need and how to get it.
Hope that helps. cheers, Jon.
If you tell us what the monitor is doing, the solution may not require knowing what voltage is at what pin - especially since some of the voltages may be oscillating!
In order to know this information I need to know the voltage herhe is the formaula using ohms law power = current x voltage this will be stamped on the compressor. If you still need help let me know.
There is a panel in the right side inner fender that you need to remove to find your battery[i know ,why why why].You may need to pull the right front tire off to gain access to it.
first you need to know what size the engine is in canada its metric , how many litre? in the u.s. its cubic inches. is the engine a 4cyl. , 6cyl. or 8cyl. most tune ups nowadays consist of sparkplugs and sparkplug wires , and like the other you need to know the size of the engine. its better to go to a oil change garage when they have a special deal on.
