Question about Zebra 105SL Thermal Label Printer
I have installed a Zebra 105 thermal printer to Windows xp using an usb to DB 25 cable and the printer is saying it is offline Printer is powered on but doesn't seem to be commuicating to Windows
Posted by siredale43 on
urjii
    New Friend:
  • 76 Answers
Eenyutu beeka
Posted on Jun 23, 2011
Cannot connect to printer anymore
make sure you have the current drivers for this printer are loaded. and select the wired set up configuration type. go to control panel select printers and see if the printer is visable to your pc. if not start over and reconfigure a new printer. and
follow the prompts. and may i also suggest going to there web site and check for the latest and the greatest on your model.
Apr 09, 2017 | Zebra QL 420 Thermal Label Printer
Zebra 2844 Printer was fine...unplugged USB then plugged into a different port on the same computer now it won't print. Says error in the printing status. It is not offline or paused.
This is due to windows which has attributed a new virtual usbport.
Go to the printer port and try another one (the last one for example)
Jul 31, 2011 | Zebra LP 2844 Thermal Printer
Zebra LP 2844 Printer Error, Cannot Print
Try this
START
SETTINGS
PRINTER/FAXES
in the pop up window go to
FILE/SERVER PROPERTIES
DRIVERS
SELECT THE MFC5440 DRIVER AND REMOVE
SELEST THE LP 2844 DRIVER AND REMOVE
Now go to www.seagullscientific.com and download the Zebra driver pack, once downloaded run it and install the Zebra Lp2844 to with the USb port.
This should solve the problem, if not please come back.
trevor
Feb 15, 2010 | Zebra LP 2844 Thermal Printer
Zebra 105SE 25 pin serial cable
error can be on the pc.side or the printer's:
check
- if in windows the LPT ports are addressed properly (if u got a many usb ports, then windows adresses these first and skips the older lpt's- same applies when using an external usb-hub/splitter!)
- that there are no dma or irq conflicts
(see device manager)
- if the right driver is installed, if it suits the windows version u are using/has been written for it
- doublecheck printer against another printer
on your pc using same port
- and/or try to connect it to another pc
so u make sure on which side the error ocurs!
least: check the cable itself
Jun 13, 2009 | Zebra 105Se Thermal Printer
Printer printing from PC W/2000 but not with XP
Hi Kmcnew,
This issue could occur if the connections are not proper.
If the printer is connected using USB cable then you need to make sure that the printer is installed on DOT 4 port.
We need to also make sure that the driver for this printer is installed and listed under printers and faxes.
May 14, 2009 | Zebra 105Se Thermal Printer
Zebra LP 2844 printer will not print anything but the test page
possibly not a real LP2844 but an LP2543, a printer mass produced for and used by UPS. refurbishers change the label and sell as LP2844 because they are almost identical.
if it has an AC-AC adapter, it is an LP2543. LP2844 uses a AC-DC adapter, and all LP2844's have USB ports.
Mar 24, 2009 | Zebra LP 2844 Thermal Printer
Driver for Zebra 105se
Hi spydo...
Zebra 105se drivers (xp/vista/win7/win8) can be found at driverupdate us
It will take 2 mins from you to install...
I hope I have helped you...
enjoy
Mar 03, 2009 | Zebra 105Se Thermal Printer
Zebra 105 SE Printing Blank Labels
You need the correct driver for the 105Se. The 300 dpi SL driver is not compatible.
Unfortunately, Zebra does not make it's older drivers available online. You will need to locacte someone with the correct driver for whichever version of Windows you are using.
Steve
Feb 13, 2008 | Zebra 105Se Thermal Printer
How to configure the Zebra S500 using a USB to Parallel adapter?
The Zebra Stripe S500 has a RS-232 SERIAL interface using a DB-25 connector . You'll need a USB to SERIAL converter, not parallel. Be sure that the baud rate and data/stop bits are set the same on the printer and interface converter. Generally speaking, use the fastest setting possible (19200 baud) unless you encounter problems.
Oct 30, 2007 | Zebra Stripe S500 Thermal Label Printer
Zebra 105SL Thermal Label Printer Logo
194 people viewed this question
Top Zebra Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Marvin
Marvin
Muntejaya Ginting
Muntejaya Ginting
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
