Question about Canon NP 6035 Copier
Canon 6035 keeps telling me to add toner when it is already full...error goes away after i open and close the hopper door..this seems to happen after every 5 or so copies(sorting and stapeling)
  • Canon Expert
  • 270 Answers
How do you know it's full? Did you record the copy count when you put the toner in? The only time the copier will indicate that it needs toner is when the developer unit is empty or if the toner sensor is not in contact with toner, you should hear a very high pitch squeal sound coming from the copier. If you are sure you have toner inside the developer unit then the toner sensor is bad. Does shaking the developer unit back and forth a few times help? Maybe the toner has developed a cave inside where the toner is supposewd to be touching the toner sensor.
Posted on Jun 27, 2011
6ya staff
SOURCE:
I have a Ricoh Aficio 1013F that has a about 65000 copy count. I replaced the drum/imaging unit a few months ago. recently, we stupidly let the machine run a week or so while it was calling for a toner...
I think you will have to reset it ..and the procedure to follow is this..
take it slow and be sure it is the correct one ..If it seam not to work try again ..
Press "clear mode" key then enter107 then press and hold down "clear/stop" key, touch on screen for "copy" then press 5992 hit enter, touch 0 to print out the standard setting list, turn off the copier when you finish.
Aug 13, 2011 | Ricoh Aficio 1013F Copier
How do you replace toner for canon np 6035 copier
open the front cover, then you will need to slide out the piece the toner goes into, upper right side. Set the toner cartridge on top. You will see a tab to pull toward you, so the toner will drop down into the copier. Push the tab back in. Then push the cartridge toward the back of the copier a little and pull up.
May 15, 2010 | Canon NP 6035 Copier
I have a problem with code E020 (canon 1120)
E020 - The toner is not adding correctly into the developing assembly.
1) If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. 2) If the hopper is 1/2 full or less, the worm gear splits under normal use.
1) Advise customer to add toner only when the toner light is lit, right away, and replace toner motor, or 2) Just replace toner motor (FH7-1762-030).
After verifying that the toner hopper is working properly, check that the web solenoid is activating. Clean the web solenoid and ensure free action. This has been known to clear an E020.
After verifying that all is well with the toner hopper unit, consider the DC controller. It has been noted that some DC controllers do not provide sufficient current to drive the hopper motor. Replace the DC controller COL97.08.25 M0000244.txt.
Apr 14, 2010 | Canon CLC 1120 Color Copier
Message says to add toner after I replace toner
Plunger from the top of the previous bottle is probably still stuck in the machine. Remove the toner bottle and check/remove .
Jun 29, 2009 | Ricoh Aficio 1013F Copier
CLC 3200 COPIER
Do you have a CLC1150 or a CLC3200. If you have a 3200 you have to open the front door and go to the low toner color and unlock the lever and remove the toner cartridge and then open the new toner box and remove the orange tabs and install the new toner cart ridge and lock the lever and close the front door. You may have to wait till the copier catch's up with replenishing the toner and you are done. If you have a 1150 you have to open both front doors and on the left side of the hopper there is a black release lever, that will allow you to pull the hopper out to open the correct toner that is low. Opent the door and install the new toner bottle and remove the emptied toner bottle and push the hopper back into place and close the front doors. Good Luck
Nov 28, 2008 | Canon CLC 1150 Color Copier
Adding toner to canon imagerunner 2200
if you have the toner open the front door take toner out of box turn the blue handle on the right side of the copier down which will move thr hopper. pull out the hopper till it stops . take the bottle and line it up so it snaps in place when it snaps in a little tab should pop put pull the tab till it says stop . This process opens the top of the hopper and bottom of the bottle then using your thumbs push the tabs on the front which closes the bottle back. then give it a little extra push and the boyyle will click off
Nov 12, 2008 | Canon (6981A002AA) for imagerunner 2200,...
How to install toner
The cartridge that you have needs to be installed onto the top of the toner hopper first, which needs to be slide out of the copier first. Follow the directions inside the door panel for sliding the toner hopper out. Once this is done, place the new toner cartridge into the slots on top of the toner hopper & press down until you hear it "click" into position. Pull the release tape, this will also open the cover on the toner hopper while releasing the toner from the cartridge. Finally, push the toner hopper door FULLY closed, at the very end, you will press on the two thumb tabs on the hopper door and the cartridge will "pop up" for removal. Good luck & let me know how it goes.
Sep 05, 2008 | Office Equipment & Supplies
Faded black and white print out (Canon NP 6035/6028)
Are you getting a E0020 code? If not there is nothing wrong with the hopper. Has the OPC unit been replaced recently? Also, have you looked at the developing unit? Dose the developer Mag. roller have a even coat or brush on it? If not have you cleaned the S-Blade or doctor blade? Also, have you cleaned the optics?
Aug 13, 2008 | Canon NP 6035 Copier
CANON CLC1000
E020 refers to incorrect operation of toner moter, jammed up toner hopper or motor stuffed.... If toner hopper is overfull, the toner motor worm gear splits as a result of the hopper becoming packed tight. If the hopper is 1/2 full or less, the worm gear splits under normal use.
add toner only when the toner light is lit, right away, and replace toner motor.
Dec 02, 2007 | Canon CLC 1000 Color Copier
Adding toner
Inside the front cover on the top right, is there a toner hopper that swings out? From the looks of the repl toner, it should be a sealed hopper. When the cartridge is locked onto the hopporit will release the latch for the toner hopper. There are usually very simple pictures on the inside of the door or toner box.
Mar 20, 2007 | Canon PC1061 Copier
Canon NP 6035 Copier Logo
73 people viewed this question
Clive
Clive
old marine
old marine
Ekse
