Question about Electrolux Dishwashers
Dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Posted on Jun 23, 2011
F2-04- Improper cartridge (destination error, life cycle error)
Identification error
model error
type error
destination error
data abnormality
Misc error
There doesn't appear to be a generic "04" error code on the Electrolux website.
Please supply a model number so I can look further
