HEALTHRIDER S300i Treadmill Motor Control Board  14470 Logo
A
Anonymous Posted on Jun 23, 2011
My son folded my healthrider s300i while it was in an incline position now the incline doesnt work is there a reset to fix this?
ernesto cuadra
Level 3:
Top Expert:
  • HEALTHRIDER Master 12,223 Answers
  • Posted on Dec 13, 2011
ernesto cuadra
HEALTHRIDER Master
Level 3:
Top Expert:
Answers
12223
Questions
0
Helped
4076297
Points
34431
1)tight the flexible cord from key panel vs display board
2) tight the display connector vs lower board
3) test the main motor board
4)motor burn to worn deck belt
5) adjust the pot in the elevation motor
6) gear is slipping repair.
sincerely
Controller what is the voltages output on a healthrider s300i
the voltage controller is the same for input voltage terminal of the motor .
test the input voltage terminal motor, if there ARE not the motor is faulty.Read my personal TIPS motor
2) test the output voltage control board, if there ARE not the control board is faulty
God bless you
1helpful
Healthrider s300i treadmill does not turn on
Check the fuses under the lower hood. One should be a 10 amp fues, the other should be 15 amp fuse.
Replace them if blown. If they should blow again, move the treadmil to an outlet closer to the fuse box/breaker box of the house. the house wiring where you have the treadmill may not be adequate for the treadmill.
1helpful
I can't fold my treadmill back up. Instead of folding upright at the 12 o'clock position it is tilted to the 11 o'clock position. Any ideas why it won't go all the way upright?
1) SEE IF SOMETHING IS PENDING between the folding section
2) Your Pin is little bend.
3) the receiver where the pin is coming is not adjusted.
sincerely.
My healthrider s300i softstrider treadmill doesn't incline anymore do you know what i can do to fix this?
1)See if flexible cable from display board is bending to lower board.
2)main motor board is faulty by worn deck belt.
3) burn motor faulty.
4) adjust the Potentionmeter from the motor (incline).
5)Defective gear in inclination motor.
Healthrider will turn on and is in demo mode. will not do anything else.
1) IF THE MACHINE ONLY RUN IN DEMO MODE, TRY TO RUN IN NORMAL POSITION.
2)PUSH AND HOLD ON THE STOP BUTTON BY 5 SECONDS.
3) IF THE PROBLEM PERSIST, TRY TO TIGHT THE FLEXIBLE CORD FROM KEY PANEL VS DISPLAY BOARD.
4)TIGHT THE DISPLAY BOARD VS LOWE BOARD(MAIN MOTOR BOARD)
5) IF THE PROBLEM PERSIST THE MAIN MOTOR CONTROLLER BOARD IS PROBABLY FAULTY.
6)bEFORE TEST THE MAIN MOTOR.
SINCERELY.
12_13_2011_9_19_40_pm.gifSeethe block diagram
1helpful
The incline on my HEALTHRIDER treadmill wont decrease. Help please!
1) tight the flexible cord from keypanel vs display board
2)tight the display board vs lower board(main motor board)
3)Test the main motor board(faulty to worn deck belt)
4)INCLINATION motor burn.
5)Adjust Pot from the inclination motor
6) the gear slip adjust or repair.
see the block diagram
I have a Healthrider Softstrider s300i treadmill and it will shut off with no warning after 35 min or so. I take out the safety key, reinsert it after a few min and it will go again.
1) you have 3 problems: mechanical+ electrical + electronic.
2) adjust the tensions from deck bel + drive belt motor
3)test the main motor without load and see what happen.
4)test the main motor board and see what happen.
see block diagram
I have a HealthRider S300i treadmill, but unfortunately, I don't have the included allen wrench. So far I've been unable to figure out what size allen wrench I need. Any idea?
you can try to rent a set at AutoZone. when you return it they will give your money back. try standard and metric. depending on manufacturer of treadmill.
My health rider treadmill s300se is stuck in the highest incline position. How do i get it level again?
Try putting the key in while holding the down incline button in. This resets the height mechanism. Repeat with the up incline button.
Worked for me.
Top HEALTHRIDER Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a HEALTHRIDER Exercise and Fitnes Expert? Answer questions, earn points and help others
