Question about Nerf N-Strike Longshot CS-6 Blaster
I recently bought my son the Nerf N-Strike Longshot CS-6. I am having trouble sliding the trigger-1 grip into place. The instructions indicate that you should "insert grip and slide back to snap into place". However, the grip does not slide all the way back. Any suggestions? Thanks in advance.
Posted by jan23rd on
5 Related Answers
Anonymous
SOURCE: Automatic sliding door on 2004 sienna is broken (cable snapped)
I'm dealing with a similar problem.... I don't have good news for you - Toyota only sells that cable as part of an assembly (just got my estimate today to replace it $2000) thats not a typo. I removed the cable and disabled the power door function - Now it works as a manual door just fine.
These are photos of what I found in my door - I'll have more pics posted soon as to what I did to make the door work soon.
http://s797.photobucket.com/albums/yy256/krtnheaz/Sienna%20Rear%20Passenger%20door/
Posted on Aug 19, 2009
Anonymous
  • 73 Answers
SOURCE: SLIDING DOOR CABLE SNAPPED
Just turn the switch off for the power door and should just be able to use it manually if the cable is not bound up.
Posted on Sep 20, 2009
Anonymous
SOURCE: My kid opened the Nerf
Take the rear bolt cover off ( 2 screws) . Reach inside with your finger and try spinning the spring. For some reason the spring will eventually move to a position that when compacted will bind with the bolt pass through hole.
Posted on Dec 27, 2010
Anonymous
  • 7 Answers
SOURCE: my son has taken apart
Below is a internal picture of the stampede.
Contact me at [email protected]
Posted on Jan 08, 2011
Anonymous
  • 70 Answers
SOURCE: On my sons Gator.
you can use bicycle tire tread by screwing it into the wheels, or there are rubber slipons for these wheels, however by taking out the flexibility allowed in sliding it CAN cause extra stress to the gears and reduce the life of them
Posted on Mar 02, 2011
My NERF gun broke.
Take it back to where you bought it. It shouldnt do that, it sounds faulty to me. I am sure they will replace a faulty item.
Feb 26, 2014 | Hasbro Nerf N-strike Longstrike Cs-6 2010...
How many and what type of batteries are required for Nerf Dart Tag Strike Fire Two-Pack?
Wow, this is hands on the dumbest question EVER.
You know, no offense or anything...
Look- this is a manually operated toy.
Unless you or I got the name screwed up, or that picture up above is incorrect...
Oh wait, I just looked at it on Amazon.
Two solutions-
1.) READ THE INSTRUCTIONS, THEY'RE THERE FOR A REASON!!!
2.) Pull the cocking slide on top of the gun back, after inserting a bullet. Pull the trigger to fire.
That's all!!!
Oh yeah, 1+1=2, in case you didn't know that either.
LOL just kidding!!!
Good luck (idk why)...
Feb 27, 2011 | Hasbro Nerf Dart Tag Strike Fire Two Pack
My kid opened the Nerf N-strike Recon CS-6, loaded darts in the clip, shot it a few rounds, and now, somehow, the cocking mechanism is stuck in the middle position, and so is the trigger (like...
Dec 25, 2010 | Nerf N-Strike Longshot CS-6 Blaster
Where is the battery compartment for a nerf havok nstrike fire ebf-25.
There is a gray battery cover a little bit above the trigger. You will see a screw hole
Jan 02, 2010 | Nerf Secret Strike As 1
Nerf gun wont shoot its cocked and when i pull the trigger nothing happens
the relese mechanism came loose and i put the pin back in if anyone needs help ill be happy to help fix it
Sep 06, 2009 | Hasbro Nerf Dart Tag Strike Fire Two Pack
Nerf N-Strike Longshot CS-6 Blaster Logo
88 people viewed this question
Top Nerf Toys Experts
Andrew Taylor
Andrew Taylor
MODERATOR USA
Alyssa DeWolfe
Alyssa DeWolfe
Level 1 Expert
Are you a Nerf Toy Expert? Answer questions, earn points and help others
