This is a problem associated with the drum not emptying water - usually a blocked empty pump filter. Electrolux have an excellent support site. Go to:
http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
and click on START ANIMATION for a walkthrough of what you need to do
Hi
This means that the filter is clogged. Unscrew the filter it'll be full of lint. E20 also means drain problem. If it actually goes through the Spin cycle then there is most likely some water still not drained out at the time of the tumble dry. Check the drain and the hose to make sure it isn't clogged.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
