Question about Kenmore Refrigerators
How do you lower the temperture in the refrigerator?
Posted by angelavperez on
Josefina Agulay
    Novelist:
  • 78 Answers
Letting perishables such as milk and eggs get warm doesn't just effect the taste; it can also allow bacteria to grow. It's essential to guard against this by adjusting your refrigerator temperature when necessary. Read below for how to do it.
1 Measure the temperature of you refrigerator. To measure the temperature in a fridge without a thermostat, just place a normal thermometer in a glass of water and place it inside the fridge. Check back 5 to 8 hours later to see what temperature the water is. This allows you to determine the temperature indirectly.
  • 2 Adjust the temperature. Once you've identified your refrigerator's temperature, it's time to change the settings. Turn the indicator to the left to make the temperature warmer, and to the right to make your refrigerator colder. It is important to only change the temperature gauge by one setting, regardless of how much you think it must be adjusted. This prevents freezing or thawing of food by making the change gradually.
  • 3 Check the temperature again after 6 to 8 hours. If it's the temperature you want, you're set. If not, move the dial one setting colder or warmer, depending on your needs. The ideal temperature for a refrigerator is 40 degrees. Wait at least 24 hours in between each adjustment to allow the fridge time to achieve that temperature.
  • 4 Prepare for changing seasons. Where you live can have a big influence on your fridge's temperatures. You may need to adjust the temperature lower in the summer and higher in the winter to maintain a constant 40 degrees. Those who live in moderate climates can worry less about weather effecting their refrigerator's temperature.
  • 5 Check the air vents. If you're having trouble achieving the right temperature, even after numerous adjustments, make sure the vents on the inside of the fridge aren't covered. This can prevent air flow, making it impossible to cool the refrigerator
  • Hope this would help you.
    Have a nice day!
    Posted on Sep 05, 2011
    The refrigerator is freezing the food in the lower parts of the refrigrator by the temperture in the upper part seem to be warmer
    If you wish to get some details about refrigerator common fault and troubleshooting ; visit the site linked here. Pull up older posts. search with the word "Refrigerator".... http://electro-medical.blogspot.com/
    Jan 22, 2017 | Refrigerators
    Refrigerator freezes everything
    you need to turn the dial to a lower number .NOT HIGHER
    Jan 16, 2015 | Refrigerators
    Kenmore icemaker model 795.7102 not producing ice
    is the metal arm in the lowered position or raised?.. needs to be down..
    Feb 02, 2014 | Kenmore Refrigerators
    Veg drawer in lower part of frig frezzes the veg. setting on ref is 4
    NEED TO CHANGE TEMPERTURE CONTROL IN UNIT. NOT CUTTING OFF SOON ENOUGH AND COLD AIR SINKS. ONLY A MATTER OF TIME AND OTHER THINGS WILL START FREEZING
    If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
    Jan 15, 2013 | GE Refrigerators
    Adjustment temperture on ge side by side model gss25gfxaww
    You can't adjust it. You can set a new set point and see if it gets there in 24 hours, otherwise you might have a problem with you fridge.
    Jul 25, 2012 | GE GSL25JFPBS Side by Side Refrigerator
    I cant get my temperture controll buttons to raise thre temperture
    could be a problem with your thermastat ,shut it down for a while all the way then turn it on and see if that helps, only turn your unit up in small increments till you reach the desired temp.
    Oct 16, 2010 | Samsung 18.8 Cu. Ft. Bottom-Mount...
    I have a GE bottom refrigerator model PDS20SBSALSS. It goes into a mode where it starts clicking like a small relay turning off and on. While it is doing this the cooling shuts down and everything gets...
    hi that may be the relay on the compressor pull the refrig out listen around the lower back where the compressor is if you dont hear it there there is a computer a little higher that maybe bad making the sound jim
    Oct 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    My GE GSS22SGMBBSCC side by side refrigerator does not cool the upper freezer portion
    Most newer GE fridges have dc fan motors controlled by a computer board. Sometimes the board just fails and sometimes the fan can cause the board to fail.
    Jun 30, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Freezer not working
    same problem but electronic temperture on in fridge but keeps flashing
    Jun 17, 2008 | Bosch Classixx KGV28323 Bottom Freezer...
    Same problem no solution not sure but need help bad fridge is getting warm
    Not cooling at all? or other symtoms that can help us get you going. Can you make sure the refrigerator is listed as Kenmore
    Here are some examples of model numbers for this appliance: 106.8782070, 596.58692890, 119.909851, 119.3101279, 198.887482, 253.835123
    •  Inside the refrigerator or freezer, on the upper left or right side wall
        •  Behind the lower crisper drawer
        •  Behind the lower toe kick-plate
        •  On the face frame of the refrigerator body
    Can you help locate these numbers so I can assist you with the drawing of that door?  TKS,Sea Breeze
    Oct 24, 2007 | Kenmore 73502 / 73504 / 73509 Bottom...
    Refrigerators Logo
    291 people viewed this question
    Top Kenmore Refrigerators Experts
    Jimmy
    geob91
    John Tripp
    John Tripp
    Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
