SOURCE: Kenmore Dehumidifier fan runs, compressor buzzes and quits
sounds like the compressor is seized.
SOURCE: My Goldstar Dehumidifier model DH404ey7
Yes. I would say that your compressor is dead...
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
SOURCE: Model BHD-301 dehumidifier compressor will
Hi bash123er,
If you're facing these problem that your dehumidifier is not producing water and compressor is shutting off then there are few things that needed to be checked on:
1. The very common problem with most dehumidifiers is the circuit board relay. If this has gone bad then it will require replacement.
2. The compressor has already gone bad. This is the problem if you notice a buzzing sound every now and then from the system.
3. You may also have a refrigerant leak. This happens when the compressor is running but coils are not getting cold at all.
4. There will be cause of low water production if the fan is not running and the compressor does. If fan is not running then you have to replace it. This also will result frozen coil.
5. Check to see also if your coil is blocked. This will also result into no water production.Air needs to be continually moved over the cold coil to get the water out of the air.
If you're not comfortable doing the checking and repair yourself then I would recommend that you contact a repairman.
Hope this helps.
Thank you for using FixYa.
SOURCE: doesn't dehumidify at any temperature any
There are many reasons why a dehumidifier willnot work or collect water.
heatman101
SOURCE: Kenmore model 580.54351800 ices up
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
