See page 73 of this manual.
SOURCE: Samsung Digimax S630 Digital Camera Driver
Please go to this link to download the driver for Samsung S630.
http://www.samsungcamera.com/customer/download/cus_down_main.asp?key=s630
SOURCE: how to transfer photos
download the photoes to your computor,wjth the help of memory card reader transfer the photoes to your SD card
SOURCE: My samsung s630 says the memory is full. I
Memory card might gone bad but can do this following troubleshooting step.
Formatting a memory
** This is used for formatting the memory. If you run [Format] on the memory, all images, including the protected images, will be deleted. Be sure to download important images to your PC before formatting the memory.
Sub menus
[No] : The memory will not be formatted. Press the menu button three times and the menu display will disappear.
[Yes] : A [Processing!] message appears and the memory will be formatted. If you run FORMAT in Play mode, a [No Image!] message will appear.
Be sure to run [Format] on the following types of memory card.
- A new memory card, or an unformatted memory card
- A memory card that has a file this camera can't recognize or one that has been taken from another camera.
- Always format the memory card using this camera. If you insert a memory card that has been formatted using other cameras, memory card readers, or PCs, you will get a [Card Error!] message.
** There might be bad sectors on your memory card.
Testimonial: "Dude you are a god. This worked! The card is good and so is the memory on the camera now. "
SOURCE: photos i have taken saved
This is a problem with the memory card. I don't know why your camera is not giving an error message of some kind- it seems to know that it can't store pictures there.
Probably the first thing to try is formatting the card. There is a function in the camera menus to do this. If it won't format or gives an error when you try, then there may be an issue with the connectors in the card slot or the card may be incompatible.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
SOURCE: I have several photos on
Look for "copy" for the option to copy the internal memory to a memory card.
