Question about Just Wireless Bluetooth Headset Wireless Headset
I just bought my Just Wireless Blue BT-15K2 and I put it on the charger. When I plug it in it illuminates a solid red and then its starts flashing red. What is the issue?
Posted by npitt11 on
5 Related Answers
machambi
ArunShree Rajendran
  • 194 Answers
SOURCE: BT-15K2 doesn't seem to hold a charge.
It is using Li-ion battery.Its life is short.If available try to replace it is the only solution.
Posted on Jan 05, 2011
sonicboomele
sonic boom electronics
  • 1557 Answers
SOURCE: I just bought the BT-15K.
it seems to be turned on try turning it of and then charge
Posted on Feb 15, 2011
phoojywg
SOURCE: bt-15k2 wont power up
You probably got a defective unit. Look at the manufacture date. If after rev072010 you're ok. Look bottom by the scan bar code for the date.
Posted on Mar 01, 2011
virginiarobi
  • 713 Answers
SOURCE: My new just wireless BT-15K2
your battery inside bluetooth is bad replace battery.
SOURCE: I can't connect my bt-15k2
Hi desireeveiga,
I see that you need assistance in getting your BT heatset to your LG phone.
make sure that the BT headset is set to discoverable mode, I believe there is a connect button on the headset that you can press and hold down for a couple of seconds this should lit up a light meaning that the BT headset is ready to be discovered by a device.
Once the Headset is set to be discoverable you can try and get you LG phone to detect the headset, Once detected the pairing code should be standard try 0000 this should get the BT headset connected to you LG phone.
I hope that this can help.
Have a nice day,
mvincentc
Posted on May 31, 2011
I recently purchased a Just Wireless Blue BT-15K2 and aside from wondering if it is truely charged it will not work without the cord being plugged into it. It is paired with my cell and as long as the cord...
Either the battery or charging circuit is defective. Has the unit been charging long enough to fully charge the batteries? Actually, if it works while its plugged in, I would suspect a faulty battery or battery circuit.
Dec 20, 2017 | Radio Communications
Pair to a sony ericsson w760a to a just wireless bt-35k2 bluetooth wireless head set
Put your device in search mode.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Dec 26, 2009 | Just Wireless Bluetooth Headset Wireless...
Can I pair my Wireless Blue BT-35K2 with my 3.0 iTouch?
Give this a try:
1. Put your device in search mode.
2. Put the bt-35k2 headset in pairing mode (press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
3. Once device detects headset, you'll be prompted for passkey; enter 0000.
Nov 18, 2009 | Apple Premium Skin Case for iTouch 2nd...
I can't place or recieve calls with my just wireless bluetooth BT-35K2
To put the bt-35k2 headset in pairing mode, press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode. Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Mar 24, 2009 | Just Wireless Bluetooth Headset Wireless...
My LED never goes solid...??
MINE HAS ALWAYS BLINKED TO BUT IT STILL WORKS MINE HAS NEVER STAYED SOLID
Aug 30, 2008 | Jabra BT160 Wireless Headset
Battery Charger Olympus li-40c
I had this problem a few weeks ago (i.e. flashing red LED). All I did was remove the power plug from the charging unit, turned it around 180 degrees, then plugged it back into the charging unit. Red LED came on steady & the battery (which is the one that came with the camera) recharged as normal.
Aug 25, 2008 | Cameras
WON"T WORK
sounds like a dead battery. Plug the origional charger into it and the front led (below the flash) should flash red. If the red led in the back of the camera flashes or stays lit, then you have the wrong charger plugged in. (the camera won't power up if the back red/green led is on when plugged in)
May 08, 2008 | Jazz DV-179 Digital Camera
Free Pulse
The following procedure will re-establish the communication link between the Headphones and the Wireless adapter, this is called "pairing". Before you start please make sure both the headphones and the wireless adapter are fully charged and turned off.
Note: The headphones and the wireless adapter come pre-paired from the factory.
1. Press and hold the power button on the headphones. See Figure 1.
Figure 1
2. Continue to hold the button down until the LED starts flashing red/blue in an alternating pattern. Release the button when the LED starts flashing red/blue. See Figure 2.
Figure 2
3. Once the headphones LED is flashing red/blue, press and hold the power button on the wireless adapter. See Figure 3.
Figure 3
4. Hold down the button until the LED starts flashing red/blue in an alternating patter. The LED will blink blue, then turn off for a few seconds then blink red/blue. Release the button when the LED starts flashing red/blue. See Figure 4.
Figure 4
5. Once both the headphones LED and the adapter LED is blinking red/blue, press the volume up button once on the headphones. See Figure 5.
Figure 5
Once the headphones is paired with the adapter, the LED on the headphones will blink blue once every two seconds. See Figure 6.
Figure 6
When the adapter is paired the LED will be solid blue. See Figure 7.
Figure 7
The adapter may continue to blink red/blue for a few seconds even after the headphones LED starting blinking blue. This is normal; the adapter may take a few additional seconds before the LED turn solid blue.
Once the headphones and the adapter are paired, it is not necessary to pair them again even if the batteries on both units are completely drained.
Additional Note: Repeated pairing will not improve the sound quality or give the headphones and the adapter a cleaner connection.
Mar 11, 2008 | Logitech FreePulse Wireless Consumer...
Just Wireless Bluetooth Headset Wireless Headset Logo
51 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
Anthony Ward
Anthony Ward
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
