Up to a point it is OK to use a heavier thread on the top with your regular thread on the bottom. If you go too heavy with the thread you might notice thread locks on the underside of material. Tightening the the tension on the top thread will usually solve this issue. However if thread is too lheavy you will not be able to adjust for tension issues. You may also find that a "too" heavy thread will catch under the throat plate. Good luck.
