My whirlpool sport washer is flashing an F30 and making a terrible noise in the origin of the soap dispenser area and appears unalble to pump water into the machine for the cycle to begin
Posted by marytinathef on
ZJ Limited
  • 17,970 Answers
F30 error indicates a problem with the dispenser. The error means the control can't advance the dispenser motor to the correct position.
This usually is a problem with the dispenser motor or the linkage is jammed.
The fist image shows how to remove the top of the washer to access the dispenser. The 2nd image may help you see the dispenser a little better.
There are some marks on top of the dispenser and at start up you should see the indicator cycle through the marks and end up on the 2nd mark for detergent dispense.
With the top off you might get a better idea of what is jamming the dispenser. Use caution running the washer with the top off.
The dispenser switch/actuator (Part Number 8183186 ) or any part can be obtained from the following link: Sears PartsDirect .
Hope ths helps to solve it.
Posted on Jun 22, 2011
Dennis Engelking
    President:
  • 643 Answers
The F30 code refers to a failure of the dispenser motor. The clicking you were hearing was probably the dispenser motor switch going on and off trying to activate the dispenser motor.
this is an easy and relatively inexpensive repair that you can do yourself.
WHAT IS F30 CODE
whirlpool duet front loading washer use a motor on top the dispenser assembly to switch the water in the dispenser between washing out the soap,bleach,and fabic softener compartments of the dispenser. Take a shop vac to the dispenser area. I think it is stopped up. It can have something in pump too
Sep 05, 2017 | Washing Machines
Whirlpool duet sport f30
Get the top off there and check the mechanical arm on the dispenser motor. then check that motor. F-30 = dispenser failure.
DUET SPORT SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 24, 2012 | Whirlpool duet Washing Machines
My washer is giving me an error message of F30 and it makes humming noise like it wants to come on but it doesn't.
The fault guide says the following about F30:
DISPENSER SYSTEM ERROR
The dispenser motor cannot be driven to its proper position
1. Unplug and disconnect power
2. Check mechanical linkage from dispensor motor to top of dispenser
3. Check wire harness connections to the dispenser motor and central control unit
4. Check dispenser motor for powered rotations
Hope this helps
Jul 07, 2011 | Whirlpool Duet GHW9150P Front Load Washer
F30 code? Makes a weird noise and drains the soap from dispenser but no water is added and won't spin.
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool WFW9200SQA10 Front Load Washer displays F30 code. What does F30 mean? Thanks
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 20, 2010 | Whirlpool WFW9200S Front Load Washer
My Whirlpool washer flashed F30. Not filling up with water.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Washing machine clicking and flashing code F-30
shaun
Jul 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F30 error code on whirlpool front load washer ''Duet''
You have a problem with your soap dispenser. This has been a very common problem. You need to order W10161052 Actuator, W10157886 Dispenser, 8183186 Actuator Motor. Put these new parts in and you will be fixed.
Nov 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Water pours from soap dispenser when starting cycle
id remove the top of the unit. 3 screw along the rear top lip. annd check the hose leading from the nto the tub, sonds as if its clogged/kinked
Apr 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
237 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
