SOURCE: Bush LCD15TV001
press the channel up and down together the menu will come up then you can use the volume up and down to toggle on what you want.if that does not work you will have to call the tech to lift off the eeprom from out of the set and resolder it back,so that the tv could reset it self.good luck.
press the up and down programme button together then press the menu button while still holding down the programme buttons.the menu will come up then you can use the volume up and down to toggle on what you want.
SOURCE: how do i retune my bush 1433
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
SOURCE: my remote control on my 37 lcd tv will not work
I also had this problem.. Try this
Turn your tv off at the wall without putting it on standby.
Leave 30 seconds then switch back on.
At the side of the tv is a menu button, press and hold it for 15 seconds.
Now press the menu button on your remote control.
You should now be able to use the remote.
