Open backdoor of the machine then turn on the machine , if you see the control board he have one tack switch onside the board press one second the machine will initialized.if the problem is occour change the temperature sensor
Turn the main switch
Press Utility and then turn on the switch side
Press Reset Trouble
Power cycle the copier
SOURCE: c5201 error konica minolta bizhub 420 i removed
reconnect again your fusing unit. then before you ON your machine you long press utility/counter then press the small circle black, then press trouble reset.off/on
SOURCE: how to reset fuser unit message for konica minolta
In Tech mode :
System 1
Initialization
Counter data fixing unit
Start button
SOURCE: how to reset fuser unit for konica minolta bizhub
whats the error cod c-d202 in bizhub c420?
