SOURCE: Toshiba Tv remote control
I NEED THE CODEOR CODES THAT TOSHIBA DVD-HD A30KU TU USE AND RECCEIVER ONKOY
SOURCE: what's the remote code to activate with a
I have found the code for the Toshiba D-R410 DVD recorder ! The code that works with my Radio Shack family 5 in 1 remote is:
1008
I hope this helps !
SOURCE: Using Vizio XRU9M universal remote. None of the
My name is Niko and I will be assisting you with this issue.
I see you where unable to find a working code for your blueray player. Please check this code list for codes that you may have not tried: http://www.vizio.com/documents/downloads/accessories/XRU9M/767Vizio%20XRU9M%20CL%202-25-10.pdf
If none of the codes work please try the code search feature of your remote.
Searching for Component Codes
If you cannot ?nd the manufacturer in the component list or the program code does not work, you can use the remote control to search for the correct component code.
To search for a component code:
1. Turn on the component.
2. Press the matching component button on the remote control (DVD, AUDIO, CABLE, or TV).
3. Press and hold the SET button until the LED ?ashes twice.
4. Press 9 9 1. The LED ?ashes twice.
5. Point the remote control at the component and then press and hold the POWER button until the component turns off.
Release the POWER button.
If the component does not respond correctly, repeat the search procedure to ?nd
another code.
Even thought the remote is a "universal remote" it is not perfect and will not work with every device out there, the remote contains a limited number of programmed codes in its memory and new codes to such a remote can not be added. So there is absolutely no guarantee that the remote would work with every device and the newest devices.
If you where to consider another remote I would recommend Logitech Harmony remotes which can be connected to a computer and have new codes loaded.
Thanks for using Fixya.
Niko
SOURCE: PAVY universal remote.I need a code to a Toshiba tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://electro-medical.blogspot.com/
