If the camera came from Japan, there will be no english in the camera. If the camera had English before, you could try to switch the language back, by using the manual and count lines in the menus, to "feel" what part of the menu you are. (Setup menu)
Slide the REC/PLAYBACK switch to the REC position (the camera icon). Set the mode dial to the camera icon. Press the MENU/SET button. Press cursor-left. Select the wrench icon. Press cursor-right. Select the talking-head icon and press MENU/SET.
Turn the camera on. Slide the REC/PLAYBACK switch to REC (camera icon) and press [MODE]. Press cursor-left, use cursor-up/down to select Setup (wrench icon), and press cursor-right. Use cursor-up/down to select the speech bubble icon, press cursor-right, use cursor-up/down to select "English" and press MENU/SET. Press MENU/SET again to close the menu.
Slide the REC/PLAYBACK selector switch to the camera symbol. Set the mode dial to the camera symbol. Press the MENU/SET button. Use cursor-up/down to select the next-to-last item on the menu (it will have a head-and-speech-bubble symbol).
You can download the English-language manual from the manufacturer's web site at http://service.us.panasonic.com/OPERMANPDF/DMCFX35.PDF
Press the MENU button to display the menu. Use down to select the toolbox, then press O (that's the center button on the multiselector). Use the cursor keys to select the wrench and hammer, then press O. Select the second item on that menu--that should be "Language". One of the choices should say "English" in English. Select that one and press O.
It appears that the camera comes in different versions, depending on the region. The "western" version has English, German and French language, but not Japanese. If you camera has Japanese menu, it is probably intended for the Asian market. It may not have English menu.
You can switch language like this:
Press Menu/OK, select the far most right option (Set), select the top option (Setup), press Menu/OK.
Select the second lowest option (laguage) (the lowest being Reset),
use > to display available languages. Use up- or down arrow to select the language and press Menu/OK.
You may use this english version of Panasonic DMC-FX37 Manual.
Using this manual and counting the menus and sub menus you can find the language. And change it to English.
In this manual especially read the belows.
If you find this explanation helpful please vote.. good luck.
Turn the camera on and press the menu button. Press the down arrow to get to the line that says "set". Press right arrow. Press down arrow until you highlight icon of person talking. Press right arrow and pick the correct language.
