Question about OKI MICROLINE 321 Turbo Matrix Printer
Need to speed it up - OKI MICROLINE 321 Turbo Matrix Printer
Posted by mannyshardwa on
A Miller
  • 8,404 Answers
This machine operates at one speed ... it is not like it has a transmission and you can shift from drive into over drive. There are a few things you can do, however.
You can remove the print driver and reinstall with a fresh copy ... go to www.oki.com/support to get the latest driver available for this printer, which works with your current operating system.
There are features in the driver which will let you make the machine appear faster ... print in draft mode for example ... Your printer may be in HI quality mode and you may select a lesser quality print for another. Since I am not intimately familiar with this particular printer, I can only suggest you go into the printer profile and examine the options you may find acceptable.
To locate the profile, open the control panel, open printer folder, find and open your printer and take a look around.
Thank you for your quesiton this morning @ FixYa.com
Posted on Jun 22, 2011
What are the cheat codes for need for speed the run?
cheat codes for need for speed the run Derek, Check the attached links,instruction and codes, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
gamesradar com
Need For Speed The Run Cheats Codes Cheat Codes Walkthrough Guide FAQ...
Need for Speed The Run
Need for Speed The Run Cheats Codes for Xbox 360 X360 CheatCodes com
Need to know what the speeds are
this is just a guess...1=sitr, 2=blend, 3=whip, 4=puree, 5=liquify
I want to change the upload speed on my laptop
the upload speed is only as good as your connection is. you could run broadband speed test. just google broadband speed test
7helpful
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
3helpful
Replaced Single Speed Pool Pump Motor with 2-Speed Motor
You will need a two speed time clock to really take advantage of real energy efficiency savings. Intermatic makes one that fits in place of the original t104 time clock. You will need to run an additional wire to the pump as well. You will have the ground. Then one common wire that is always hot whether or not you are on high speed or low speed. You could make this a white wire. Then a black wire for your high speed that is energized in high speed and a red wire for the low speed. It is important that the high and low speeds not be energized at the same time, otherwise you will hear a very unpleasant sound coming from the motor, and failure and shortened life of the motor will be realized. HTH
8helpful
1990 Prelude Automatic Transmission
Hi...
The first step you need to do on your Honda,
Is check if the Cluster show the Vehicle Speed.
If not You need to fix the Cause of not speed.
Because the Overdrive is strictly comanded at certain speed.
But if the Speed signal is good , you will need to test the Overdrive selenoid...
Ok. Letme know if you need instructions to test, or any info you need.
For try to solve your problem..
Thank you for use fixya...
OKI MICROLINE 321 Turbo Matrix Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Ekse
Alvin Barnabas
Alvin Barnabas
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
