SOURCE: Zanussi FX1465W aquacycle, beeps 5 times and end light flashes
I have the same trouble with my washing machine did you find a solution i have been told the PCB or motor drive system
SOURCE: Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
SOURCE: zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
SOURCE: Zanussi manuals
Click on 'washing machines' (below FIXYA) on this website, & search. You will get a shortlist; click on your model, below the page u will get Manual/Guides. Click on the blue, u hv your manual on line. If available that is....................
Rate me pl if helped...................
SOURCE: Zanussi aquacycle 1200 smells.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it
run for a minute or two, then stop the cycle, open the lid and slowly
add the gallon of hot tap water. Don't overfill — you just want to
raise the water level so that it is able to reach and clean the inside
top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle.
In a couple of minutes, stop it again and just let it sit for at least
30 minutes. Afterward, let the cycle finish, and open the lid to air
out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
