Question about Epson Stylus Pro 4800 InkJet Printer
When printing, it keeps printing the test page first. How can it stop printing the test page??? thx
Posted by cuttedk on
  • cuttedk Jun 22, 2011
    I did pressed the reset for 5 seconds, all the lights on and off with reset sign. But after that, it does not ask me to print the test page. I turned off the printer and on and it still prints the test page first and then the actual prints.
    Help.. T T
Subhojit Kumar Roy
    New Friend:
  • 52 Answers
Reset the printer by pressing the reset botton for atleast 5seconds. then it ask for printing the test page.............. and you have to print the test page completely... otherwise it will ask for printing the ttest page at every print......................
then switch off the printer and again on it..........
then you will see th\at the problems will be solved..................
thnx
Posted on Jun 22, 2011
Canon BJC printer keeps printing test pages
First of all save your data to a removable hdd
Then you must restore your machine
and check if problem is solved
if it doesnt work then
you must repair your toner
and refill it with best quality powder !
Mar 19, 2014 | Canon Office Equipment & Supplies
Printers always prints test page
Try to check this article if it helps: http://bit.ly/UVl5YI
Nov 13, 2012 | Lexmark E321 Laser Printer
I connected my hp C5180 to my pc then printed a test page, it started to print and hasn't stopped. It just keep printing pages of code. How do I stop this???? Tried cancelling, tried turning off...
YOU NEED TO GO TO PRINTERS...AND CHANGE HOW PAGES YOU WANT TO PRINT...AND TAKE THE PAPER OUT OF PRINTER, SO IT DOESN'T USE UP ALL YOUR INK!
HOPE THIS HELPS!
Aug 31, 2011 | HP Photosmart C5180 All-In-One InkJet...
My printer keeps printing the test page everytime its switched on, How do I stop this as wasting ink ?
Remove and reinstall the printer driver. Make sure you have the latest driver consistent with your operating system. www.hp.com/support
Feb 24, 2010 | HP PSC 1315 All-In-One InkJet Printer
Lexmark E 342 n paper jam with error code 201
According to the LexMark support page, this is most often related to not getting the print cartridge assembly properly positioned. (Left and right sides not fully in place). Another possible source is paper in the output tray when using the double sided printing feature. (This leads to grabbing an extra sheet when it tries to retrieve the paper to print the second side. Paper stock thickness will change the number of pages printed before this happens.).
I hope this helps.
Sep 03, 2009 | Lexmark E342n Laser Printer
My hp deskjet 5150 will not stop printing
If you are using Windows XP
1. Click start then run then type in cmd then click ok.
2. Type in NET STOP SPOOLER
After that in the lower right corner of your screen you should see a printer icon. Delete the queueu
If that still does not work Unplug the power from the printer then wait for 5 mins then restart your computer and turn it back on.
Nov 11, 2008 | HP DeskJet 5150 InkJet Printer
Printer
Would be better if u elaborate the issue.
For confirmation, are u able to print the self test page from the printer? This will make sure that the printer hardware itself is working fine.
Click here for information on how to print a self test page on your printer.
thx
Oct 05, 2008 | HP DeskJet F380 All-In-One Printer
Test Page
thats not the test page that is allignment page which is printing.
keep the the printed side of that page which comes out on the scanner glass.press the ---scan ---button.the on /off light will blink, wait till it stops blinking.and after that everything will be normal.
for any thing else let me know.
thanks.
Sep 17, 2008 | HP LaserJet 1200n Printer
Prints test page every time the printer is turned on
This might be an alignment page. To get it to stop, you will have to go through the alignment and new cartrige setup in the hp software. This should be located under Start/All Programs/HP folder. I'm not sure what the software would be called but it should be easy to do if you have the HP software installed. Hope this helps!
Nov 07, 2007 | HP PSC 1315 All-In-One InkJet Printer
Epson Stylus Pro 4800 InkJet Printer Logo
760 people viewed this question
Top Epson Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
