SOURCE: Unlock Pentax Optio S5z
Thank you sooo much *bsho* I had this exact same problem on my camera for about 3 weeks ,and it was really making my angry!.. Thank you so much for your solution it worked for me!
SOURCE: card locked
The card has a lock on it which must have been disturbed, just take it out and slide it to unlock.
SOURCE: I can't access my menu, a lock icon appears on the
your menu's locked (yellow icon) if it's in green mode. exit the green mode, and you'd get your menu back.
just fyi, since i helped my dad troubleshoot his cam (same model as yours) a while back.
SOURCE: I have a pentax optio M10, and the card is locked.
remove the memory card and there should be a little switch on the side,slide this in the opsite direction to where it is now and that should do it, it sometimes gets moved when you remove the memory card.
Testimonial: "Sometimes I feel so dumb!!! that was an excellent reply, and naturally completely solved tghe problem. I cant thank you enough "
